查看: 2724|回复: 1
[招聘] 【社会招聘】LSI上海研发中心2012年3月最新职位
发表于 2012-3-16 13:27:23 | 显示全部楼层 |阅读模式
有意者,请将简历发至:
Tracey.zheng@lsi.com
如有任何疑问,请发送邮件至Tracey.zheng@lsi.com或拨打电话021-24191709.
也可加我msn: zql975504@hotmail.com
或者微博啊:
http://www.weibo.com/u/1752448637
1.
Read Channel Verification Engineer
JOB DESCRIPTION:
As a member of the Read Channel team, candidate must be willing to work as an extended
member of the design team. Duties will include functional verification of Storage read
channel mixed-signal IP. Candidate will be expected to contribute to design and development
of System Verilog based verification environment and will be responsible for verification
closure of block/chip/system level functions for mixed signal based IP. Experience with
System Verilog and functional coverage methodologies are required. Must be willing to
follow a disciplined verification methodology and to work closely with a multi-location,
international design team. Excellent teamwork and communication skills are required.
PREFERRED EXPERIENCE:
BSEE with 3-5+ years of design and/or verification experience required, MSEE preferred.
Required knowledge and skills:
- Expertise in System Verilog required
- Good understanding of Digital Signal Processing
- Good understanding of Analog and Digital Circuits
- Very good analytical/debugging skill
- Good verbal and written communication skills
Desirable skills:
- Knowledge of Verilog-AMS, Perl
- Knowledge of verification methodologies including functional coverage and constrained
random testing
- Knowledge of VLSI design flows & DFT
- Familiarity of high level programming language
- Experience working with globally distributed team
2.
Digital Design Engineer-Shanghai
Job Responsibilities
Working with an Architecture/Algorithm Development Team to finalize system architecture
for optimal implementation of digital signal processing algorithms, including architectural
definition and tradeoffs, die size, power estimation.
Skill required:
Digital logic design, verilog coding, logic synthesis, both RTL and gate level verification,
formal verification and static timing analysis. Unix shell, Perl scripting, C/RTL co-simulation.
Sound theory background  of communication and Digital signal processing.
3.
ASIC Design Engineer
Job Description
- Looking for a candidate who is familiar with digital IC design methodologies, understands all stages of ASIC design flows, and is experienced with state-of-the-art design tools. The candidate has solid knowledge of timing closure and synthesis flow and is experienced in logic design and verification.
- Minimum requirements:* Knowledge of HDL and experience in behavioral and RTL coding, Verilog preferred
- Knowledge of logic synthesis and timing analysis.* DSP and communications background is a plus
Requirements/Qualifications (Education)
- B.S. required, MS/Ph.D. a plus. At least 3 years of experience
4.
ASIC Customer Engineer-DFT
Job Description
- LSI Corporation offers an excellent opportunity to contribute to a team environment and to grow personal career path. You will be working with internal and external customers to develop state of the art IC solutions utilizing LSI's leading edge CMOS cell-based ASIC technologies. You will have responsibility for ASIC designs through all of the key development and implementation phases including RTL analysis, synthesis, design optimization, timing verification, simulation, test insertion, physical design, vector generation, and post-prototype test support. Candidates will have opportunity to work on the latest 40nm/28nm designs.
Education: BS/MS Electrical, Computer Engineering or Equivalent
- DFT: The ideal candidate should be strong in all DFT (Design for Test) for all aspects. This would include
- scan/TDF, TestKompress, MEMBIST/BISR, JTAG and etc. Having STA skills is a plus for all aspects of test. Responsible for support / debug of customer designs after delivery of prototypes
5.
Signal Integrity & Application Engineer
JOB DESCRIPTION:
This position will define SI requirements on advanced memory interface solutions including
DDR3/4, RLDRAM III and ONFI 2.2 NAND Flash interfaces. Work in a co-design environment
by providing specifications to IO and package designers. Develop IP implementation
guidelines based on feasibility analysis and support internal design teams. Provide complete
application support to customers by providing SI Kits, Timing Budgets and System Design
Application Notes.
- Education Requirements: MSEE with 5 or BSEE with 7 years experience in high speed
interface design and signal integrity.
- Hands on experience with high speed interfaces (DDR1/2/3, RLDAM II, QDR SRAM,
Flash, USB) implementation and hardware system experience is a must..
- Experience in Serial Interface architecture, protocols, Backplane design/analysis is
preferable.
- System Signal Integrity analysis experience with HSPICE is must and familiarity with tools
such as Agilent ADS, Sigrity Power-SI, Ansoft HFSS, Apache tools.
- Knowledge of IBIS modeling, board & package model extraction, via modeling.
- Proficiency in Electromagnetic, Transmission-line & S-parameters theory and modeling.
- Understanding of signal integrity analysis parameters and evaluate trade-offs between
design parameters to determine an optimum solution space.
- Simulating and analyzing Power distribution network.
- Firmware knowledge and programming skills in Excel, PERL, Verilog and Matlab is
preferred.
- Experience using lab measurement tools such as oscilloscopes, TDR, VNA and software
tools such as Labview, PLTS.
- Strong written and oral communication in Chinese and English with customer service skills
6.
SerDes Application Engineer
DESCRIPTION OF DUTIES
Applications engineer for custom silicon integrated circuits with SerDes interfaces located in
Shanghai, China. Work as part of a team of highly skilled applications engineers located in
Milpitas, CA, and Allentown, PA, along with local field applications and sales engineers. The
successful candidate will work directly with the customer supporting custom silicon IC’s with
responsibilities including product definition, SerDes integration, channel definition and analysis,
system bring up, and production ramp. This individual must be highly motivated and capable of
working independently or as part of a team. Expertise in high speed serial interfaces and PCB
signal integrity is required.
- Oral and written communication skills in both Chinese and English
- Microsoft Office Tools including Excel, Powerpoint, and Word
- Detailed understanding of serial communications
- Knowledge of serial communications standards including XAUI, SRIO, OIF-CEI,
IEEE802.3ap, Fibre Channel, SFF-8431
- Knowledge of semiconductor technology
- Desired: Use of state of the art test equipment including sampling scopes, BERTs, real
time scopes. High speed PCB layout design techniques and modeling
Education/Certifications
BSEE plus 8 years relevant experience in semiconductors with serial interfaces or
MSEE plus 5 years relevant experience in semiconductors with serial interfaces
7.
Field Coreware Engineer
JOB DESCRIPTION:
This position will support DDR/DDR2/DDR3, QDR, RLDRAM, and/or NAND Flash memory
Interface IP applications and their future versions. Customer interface. Generate application
notes. Work with development teams to provide customer technical support. Memory Interface
Phy IP customization.
- Verilog RTL coding, logic simulation, Synsopsys Design Compiler, Synopsys PrimeTime
STA, Good communication skill, Technical writing (Tech Manual, App Notes, Datasheet)
- BSEE or equivalent, and 3 years logic design industrial experiences, preferrable in
DDR/DDR2/DDR3 SDRAM, QDR SRAM, RLDRAM, and/or NAND Flash memory
Interface
8.
Software Quality Assurance(SQA)
Education and Experience Requirements
BS in Electrical Engineering, Computer Science, or Computer Engineering is required with 6+ years of firmware development.
M.S. preferred with 4+ years in software / hardware validation
Knowledge, Skills, and Abilities
Quick learner with high level of self-motivation and dedication, with ability to deliver high quality products on time
Meticulous, methodical, uncompromising, and creative in
testing
Experience in software debugging, problem creation and trapping
Experience in devising testing / validation methodology is strong plus
Communicate effectively in a team, able to multitask effectively in fast-paced environment.
Understanding of NAND Flash concepts, knowledge of Flash management techniques, including wear leveling, garbage collection (strong plus).
Knowledge and hands-on experience with storage protocols is preferred (SAS / SATA)
9.
Firmware Engineer
M.S. preferred with 4+ years in firmware development.
Must demonstrate expertise in design and implementation of event-driven, real time firmware solutions using C/C++ programming
Must be able to work with ASIC and software engineers in a collaborative environment
Must have an excellent computer science background and demonstrated strength in designing efficient embedded firmware for storage or networking products
Firmware/System debug skills utilizing debugger, protocol analyzer is required
Good understanding of RTOS concepts including task switching, deadlocks, and resource management issues is required
High level of skill in problem recreation, trapping and resolution, possess good written and verbal communication skills.
Understanding of NAND Flash concepts, knowledge of Flash management techniques, including wear leveling, garbage collection (optional but strong plus).
10.
Sales Account Manager-Shenzhen
Come join us! Exceptional possibilities await you at LSI’s rapidly expanding Flash Component Division (FCD) in Shanghai. We are one of the top innovators in data storage today, by pioneering use of standard flash in consumer, and enterprise applications, we revolutionize storage in reliability, performance and energy efficiency.
LSI Sandforce Flash Storage Processor is by far the best selling SSD processor on the market today, and is named Product of the Year by Electronic Products Magazine.
Requirements:
1.
5+ years working experience in Semiconductor industry, Flash business experience is preferred.
2.
3+ years working experience in global company
3.
Good English communication both in written and in verbal
4.
Self motivated person with passion for success
5.
Has disti management skills
6.
EE background
发表于 2012-3-16 21:11:54 | 显示全部楼层
本科工作一年半,能力自己觉得还不错,应聘 Digital Design Engineer,有面试机会没?
GMT+8, 2025-10-5 11:45 , Processed in 0.016914 second(s), 6 queries , Gzip On, Redis On.
