查看: 2821|回复: 1
[求助] 仿真问题关于 'getSpectreFiles'
发表于 2012-3-15 09:47:08 | 显示全部楼层 |阅读模式
提示“Internal error found in spectre.Please run 'getSpectreFiles' or send the netlist, the spectre log file, the behavioral model files, and any other information that can help ident Segmentation fault.
”问题补充: 从别人那里拷过来的虚拟机,别人能仿,我的不能啊
发表于 2012-10-30 03:09:16 | 显示全部楼层
楼主是不是使用的是mmsim61~楼主的机器是不是AMD的CPU?如果是的话~就很正常了~~mmsim61不兼容AMD的CPU建议升级更新的版本~
GMT+8, 2025-12-11 19:51 , Processed in 0.017684 second(s), 6 queries , Gzip On, Redis On.
