报错如下: 像是加的port没有连接到metal1
Extraction Errors and Warnings for cell "inv.calibre.db"
WARNING: Unattached label:
Name "VDD!" at location (1.08,1.735) on layer 141
Name "OUT" at location (4.67,6.53) on layer 141
Name "IN" at location (5.475,9.15) on layer 141
Name "GND!" at location (8.495,9.73) on layer 141
WARNING: Unattached port pads; port ignored:
Port name: VDD! on layer 141 at location (1.08,1.735)
Port name: OUT on layer 141 at location (4.67,6.53)
Port name: IN on layer 141 at location (5.475,9.15)
Port name: GND! on layer 141 at location (8.495,9.73)
WARNING: Invalid PATHCHK request "GROUND && ! POWER": no POWER nets present, operation aborted.
WARNING: Invalid PATHCHK request "POWER && ! GROUND": no POWER nets present, operation aborted.
WARNING: Invalid PATHCHK request "! POWER && ! GROUND": no POWER nets present, operation aborted.
WARNING: Invalid PATHCHK request "! LABELED": no LABELED nets present, operation aborted.
## C A L I B R E S Y S T E M ##
## L V S R E P O R T ##
REPORT FILE NAME: inv.lvs.report
LAYOUT NAME: inv.calibre.db
SOURCE NAME: /home/tsm0001/verify/out_richard/inv.src.net ('inv')
RULE FILE: /home/tsm0001/verify/out_richard/_SmicSP2T_cal035_epm_realhv3.3V_p2mtx.lvs_
LVS MODE: Mask
RULE FILE NAME: /home/tsm0001/verify/out_richard/_SmicSP2T_cal035_epm_realhv3.3V_p2mtx.lvs_
CREATION TIME: Tue Mar 13 16:45:46 2012
CURRENT DIRECTORY: /home/tsm0001/verify/out_richard
USER NAME: tsm0001
CALIBRE VERSION: v2011.2_34.26 Wed Jul 6 05:20:09 PDT 2011
OVERALL COMPARISON RESULTS
# # INCORRECT #
Error: Different numbers of nets (see below).
Error: Connectivity errors.
INITIAL NUMBERS OF OBJECTS
Layout Source Component Type
Ports: 4 4
Nets: 4 4
Instances: 1 1 MN (4 pins)
1 1 MP (4 pins)
Total Inst: 2 2
NUMBERS OF OBJECTS AFTER TRANSFORMATION
Ports: 4 4
Nets: 8 4 *
1 1 MP (4 pins)
Total Inst: 2 2
* = Number of objects in layout different from number in source.
lvs文件中关于port的定义如下:
TEXT LAYER 141 ATTACH 141 metal1
PORT LAYER TEXT 141
TEXT LAYER 61 ATTACH 61 metal1
PORT LAYER TEXT 61
#IFDEF TOPMETAL 3
TEXT LAYER 143 ATTACH 143 metal3
PORT LAYER TEXT 143
TEXT LAYER 363 ATTACH 363 metal3
PORT LAYER TEXT 363
TEXT LAYER 142 ATTACH 142 metal2
PORT LAYER TEXT 142
TEXT LAYER 62 ATTACH 62 metal2
PORT LAYER TEXT 62
#ENDIF
#IFDEF TOPMETAL 2
PORT LAYER TEXT 142
PORT LAYER TEXT 62
#ENDIF |
