楼主: windazove
Agilent Technologies SystemVue 2011.10(附crk)
发表于 2025-3-7 23:38:41 | 显示全部楼层
nationzyuchen 发表于 2012-4-12 14:43
**** 作者被禁止或删除 内容自动屏蔽 ****
里面没有systemvue lte控件的代码啊... 是否破解不完全
只有lte verification lib ,无 exploration lib
发表于 2025-3-7 23:41:14 | 显示全部楼层
无Baseband Exploration库
LTE Specific License Requirements
If you have LTE Baseband Verification License then the first time your will generate C++ code, LTE C++ header files will be copied to "\SystemVue\ 2023\LTE_8.9" under "My Documents" directory for your user account, where LTE_8.9 represents LTE version 8.9. To build any C++ code generated using LTE models in your design requires these headers to be present in that directory. You will also need LTE license to run the generated code. If you have purchased LTE Baseband Exploration library then you will have access to complete LTE source code and you can use it in a similar way as W1718 source code.
发表于 2025-3-7 23:43:14 | 显示全部楼层
GMT+8, 2025-9-13 11:00 , Processed in 0.017243 second(s), 3 queries , Gzip On, Redis On.
