查看: 8320|回复: 18
[求助] (IEEE) MEMS gyroscope drive-mode paper download
发表于 2012-3-6 14:08:09 | 显示全部楼层 |阅读模式
悬赏80资产已解决
1. Design on the Driving Mode of MEMS Vibratory Gyroscope
http://ieeexplore.ieee.org/xpl/freeabs_all.jsp?arnumber=4694016
2. Analysis and design of Gyro-drive mode loop with amplitude control
http://ieeexplore.ieee.org/xpls/abs_all.jsp?arnumber=5404088
3. An Analysis to Improve Stability of Drive-Mode Oscillations in Capacitive Vibratory MEMS Gyroscopes
http://ieeexplore.ieee.org/xpls/abs_all.jsp?arnumber=4805508
4. An amplitude regulation for gyroscope drive loops based on phase-shifting
http://ieeexplore.ieee.org/search/freesrchabstract.jsp?tp=&arnumber=5537912&openedRefinements%3D*%26filter%3DAND%28NOT%284283010803%29%29%26searchField%3DSearch+All%26queryText%3Ddrive+Gyroscope
5. Stability analysis of MEMS gyroscope drive loop based on CPPLL
http://ieeexplore.ieee.org/search/freesrchabstract.jsp?tp=&arnumber=6075067&openedRefinements%3D*%26filter%3DAND%28NOT%284283010803%29%29%26searchField%3DSearch+All%26queryText%3Ddrive+Gyroscope
6. A Novel Closed-loop Drive Circuit for the Micromechined Gyroscope
http://ieeexplore.ieee.org/search/freesrchabstract.jsp?tp=&arnumber=4304106&openedRefinements%3D*%26filter%3DAND%28NOT%284283010803%29%29%26searchField%3DSearch+All%26queryText%3Ddrive+Gyroscope
7. Phase correction in digital self-oscillation drive circuit for improve silicon MEMS gyroscope bias stability
http://ieeexplore.ieee.org/search/freesrchabstract.jsp?tp=&arnumber=5667594&openedRefinements%3D*%26filter%3DAND%28NOT%284283010803%29%29%26searchField%3DSearch+All%26queryText%3Ddrive+Gyroscope
8. A 104dB SNDR Transimpedance-based CMOS ASIC for Tuning Fork Microgyroscopes
http://ieeexplore.ieee.org/search/freesrchabstract.jsp?tp=&arnumber=4115043&openedRefinements%3D*%26filter%3DAND%28NOT%284283010803%29%29%26searchField%3DSearch+All%26queryText%3DA+104dB+SNDR+Transimpedance-based+CMOS+ASIC+for+Tuning+Fork+Microgyroscopes
最佳答案
发表于 2012-3-6 14:08:10 | 显示全部楼层
Here you go!
Gyro.rar (6.94 MB , 下载次数: 242 )
发表于 2013-2-6 21:46:07 | 显示全部楼层
发表于 2013-2-28 12:52:46 | 显示全部楼层
还不错哦 !!!
发表于 2013-8-27 18:20:31 | 显示全部楼层
Thanks for sharing!
发表于 2013-10-4 17:54:31 | 显示全部楼层
thanks man
发表于 2014-1-12 13:54:41 | 显示全部楼层
gooooooooooooood~~~
发表于 2014-1-12 13:55:07 | 显示全部楼层
回复 1# abab1394
    fdfdfd
发表于 2014-1-12 13:55:52 | 显示全部楼层
回复 8# yehonglei
   fddgg
发表于 2014-1-12 13:58:15 | 显示全部楼层
fehhrh
GMT+8, 2025-9-17 06:08 , Processed in 0.029233 second(s), 7 queries , Gzip On, Redis On.
