楼主: mengyj0706
CentOS 6.2 安装IC615,MMSIM101,Calibre2011.4教程
发表于 2012-5-8 22:02:17 | 显示全部楼层
verygood
发表于 2012-5-11 22:26:41 | 显示全部楼层
这个是要顶的。
发表于 2012-5-27 02:34:11 | 显示全部楼层
回复 1# mengyj0706
I don't think the hotfix is a problem because I can use it without any problem.
You must make sure 2 things
(1) License. The following license is working fine with me. Be sure that there is no other cadence license before this one. I had a cadence license for ic51 before this one and ic61 license got impacted. I got error message like you have.
http://bbs.eetop.cn/viewthread.php?tid=321723&highlight=ic615
(2) The current patch is only working for 32bit. You must set CDS_AUTO_64BIT=NONE. I don't know why, after I installed ic615, this parameter is automatically set to "ALL" if you don't set it to "NONE". Use "setenv" to check this parameter.
You should be able to make it work.
发表于 2012-5-27 10:40:01 | 显示全部楼层
回复 14# camelotking
hi, i also use the same license, but it doesn't work for me. Should I use this license only or after running "./patch"? Thanks.
发表于 2012-5-30 01:29:19 | 显示全部楼层
回复 15# bigb24
You must use patch.
发表于 2012-6-5 23:41:40 | 显示全部楼层
感謝分享
发表于 2012-6-7 10:18:38 | 显示全部楼层
DDDDDDDDDD
发表于 2012-6-7 10:19:42 | 显示全部楼层
DDDDDDDDDDDDDDDDDDDDDDDDDDD
发表于 2012-6-19 14:48:31 | 显示全部楼层
回复 8# dpig101
    /MMSIM10/tools/bin/spectre
发表于 2012-8-16 00:12:58 | 显示全部楼层
发一个贴还挺赚钱的吗!哈哈哈!
GMT+8, 2025-12-5 10:46 , Processed in 0.016149 second(s), 2 queries , Gzip On, Redis On.
