楼主: xinu2009
[求助] metal 1 的宽度为0?
发表于 2012-3-2 11:22:30 | 显示全部楼层
回复 10# xinu2009
    Sroute的时候就用到呀
 楼主| 发表于 2012-3-2 12:33:27 | 显示全部楼层
回复 11# damonzhao
   老兄 我加你下MSN
 楼主| 发表于 2012-3-5 14:19:28 | 显示全部楼层
问题没有解决  继续求解
发表于 2012-3-5 16:13:20 | 显示全部楼层
同关注!
发表于 2012-12-6 17:14:57 | 显示全部楼层
版主,这个问题最后的原因是什么啊
发表于 2012-12-6 19:52:21 | 显示全部楼层
在关注这个问题,后来咋解决了?
发表于 2014-11-21 13:03:06 | 显示全部楼层
回复 13# xinu2009
问下版主 这个问题解决了吗 我也遇到这样的 warnings啦
发表于 2014-11-21 13:04:41 | 显示全部楼层
回复 9# damonzhao
版主,我的也遇到了同样问题,lef读入没问题,log部分如下:#Start globalDetailRoute on Fri Nov 21 12:37:24 2014
#Generating timing graph information, please wait...
#72096 total nets, 241 already routed, 241 will ignore in trialRoute
#Option routeTdrEffort has been set to 3 by user
#Dump tif for version 2.1
#Write timing file took: cpu time = 00:00:11, elapsed time = 00:00:11, memory = 477.00 (Mb)
#Done generating timing graph information.
#Start reading timing information from file .timing_file.tif ...
#The worst setup slack read in is 0.202
#No hold time constraints read in
#Read in timing information for 61 ports, 71940 instances from timing file .timing_file.tif.
#NanoRoute Version v08.10-p008 NR081027-0018/USR58-UB
#WARNING (NREX-28) The height of the first routing layer M1 is 0.000000. It should be larger than 0.000000
#WARNING (NREX-30) Please also check the height and metal thickness values for the routing layers heigher than routing layer M1
#WARNING (NREX-4) No Extended Cap Table was imported. Not enough process information was provided either and default Extended Cap Table database will be used.
#Merging special wires...
请版主指导一二啊
发表于 2014-11-21 15:44:55 | 显示全部楼层
回复 18# 522526tl
   然后就不能跑了?
发表于 2014-11-21 15:47:02 | 显示全部楼层
回复 19# damonzhao
能跑,跑完后 0个fails 但是有好多warnings
GMT+8, 2025-12-20 07:50 , Processed in 0.022002 second(s), 4 queries , Gzip On, Redis On.
