查看: 3593|回复: 1
PCB
发表于 2006-11-23 13:14:36 | 显示全部楼层 |阅读模式
Qualification
- Univeristy degree in Electronic Engineering,
- Senior Electronic Engineer
- Electronic Printed Circuit Boards, Computers High skilled, Q.A. of EE products.
- EE Manufacturing with problem solving experinece.
- Good English
Main Job Responsibilities
- PCB Projects Follow up, from supplier to shipment. Link about PCB follow up with R&D.
- Support to PCB projects Supply Chain definition.
- Support to DS check, edit and modification. Documentation support, Test Methods, etc.
- Electric and Electronic Components IQC support Electronic support for Quality Control
- Engineering Samples preparation and testing follow up (definition & judgement)
- Special EE measuring and experiment procedures. ESD protection factory responsible.
- Keep record of R&D drawings and requirements on Electronic Comp.
- Support Laboratories Homologations when needed.
Contact: laurel.wang@mentorjob.com
发表于 2008-2-22 19:40:56 | 显示全部楼层
i will try
GMT+8, 2025-12-23 12:30 , Processed in 0.016012 second(s), 6 queries , Gzip On, Redis On.
