查看: 6531|回复: 14
IEEE-A 2.6GHz&5.2GHz Frequency Synthesizer in 0.4um CMOS(Razavi)
发表于 2006-11-23 09:07:24 | 显示全部楼层 |阅读模式
A 2.6-GHz/5.2-GHz Frequency Synthesizer in 0.4um CMOS Technology  2000
by
Christopher Lam and Behzad Razavi, Member, IEEE
Abstract
    This paper describes the design of a CMOS frequency
synthesizer targeting wireless local-area network applications in
the 5-GHz range. Based on an integer- architecture, the synthesizer
produces a 5.2-GHz output as well as the quadrature phases
of a 2.6-GHz carrier. Fabricated in a 0.4- m digital CMOS technology,
the circuit provides a channel spacing of 23.5 MHz at 5.2
GHz while exhibiting a phase noise of 115 dBc/Hz at 2.6 GHz and
100 dBc/Hz at 5.2 GHz (both at 10-MHz offset). The reference
sidebands are at 53 dBc at 2.6 GHz, and the power dissipation
from a 2.6-V supply is 47 mW.
Index Terms—Frequency dividers, oscillators, phase-locked
loops, RF circuits, synthesizers, wireless transceivers.
IEEE JOURNAL OF SOLID-STATE CIRCUITS, VOL. 35, NO. 5, MAY 2000
A 2.6GHz_5.2GHz Frequency Synthesizer in 0.4um CMOS Technology00.pdf
203.84 KB, 下载次数: 40 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2006-11-23 10:05:26 | 显示全部楼层
good one
发表于 2006-12-26 08:20:40 | 显示全部楼层
好东西啊,谢谢楼主
发表于 2006-12-26 08:25:20 | 显示全部楼层
什么叫未定义操作
发表于 2007-2-16 10:47:28 | 显示全部楼层
it is a very good paper
thanks a lot
发表于 2007-3-4 02:28:27 | 显示全部楼层
谢谢楼主。
发表于 2007-3-4 11:10:24 | 显示全部楼层
thank you for your sharing
发表于 2007-3-4 17:33:10 | 显示全部楼层
谢谢谢谢放
发表于 2007-3-22 23:32:10 | 显示全部楼层
发表于 2007-3-24 16:12:47 | 显示全部楼层
00000
GMT+8, 2025-12-25 17:02 , Processed in 0.022952 second(s), 6 queries , Gzip On, Redis On.
