查看: 3694|回复: 1
[讨论] in the virtuoso ,the tip :undefined function-_hilowmemorydbox
发表于 2012-2-9 11:23:05 | 显示全部楼层 |阅读模式
Hello, is there anybody ever used the cadence ic615, and when you log in the virtuoso ,the tip appears as :undefined function-_hilowmemorydbox?
thank you!
发表于 2013-5-9 22:07:01 | 显示全部楼层
I meet same problem , the system I use is rhel 5.2, when I try it in rhel 5.8, this issue clean, so I think it should be some linux system lib compatible problem to make this error. I am not very sure what the critical lib file to make this.
GMT+8, 2025-12-20 16:13 , Processed in 0.012030 second(s), 3 queries , Gzip On, Redis On.
