创建外设模板时选择了256个寄存器,其他都是默认,未添加其他功能,加入工程后,在generate netlist时提示错误:
ERROR ortability:3 - This Xilinx application has run out of memory or has encountered a memory conflict. Current memory usage is 3131932 kb. You can try increasing your system's physical or virtual memory. If you are using a Win32 system, you can increase your application memory from 2GB to 3GB using the /3G switch in your boot.ini file. For more information on this, please refer to Xilinx Answer Record #14932. For technical support on this issue, you can open a WebCase with this project atta
ched at http://www.xilinx.com/support.
已经在Boot.ini加入了/3GB(加入前Current memory usage is 20xxxxx kb.)。是否是软件问题?有谁使用过大量寄存器的外设? |
