查看: 2822|回复: 2
[原创] why 's the ddr_hp_controller signal local_init_done always "0"
发表于 2012-1-5 15:42:17 | 显示全部楼层 |阅读模式
Hi,
The HPCII native interface documentation is very poor, so I try to simulate my design to verify read and write operations.
I use Quartus 10.1 sp1 / modelsim 6.6c
HPC II : - PSC A2S56D40CTP-G5 DDR (cycIII starter kit DDR), burst x4
- full calibration & generate simulation model options
I made a testbench with my ddr_driver (which drive local signals), ddr IP and quartus generated memory model.
The internal PLL works (phy_clk, mem_clk, aux_full_rate_clk... are generated) but the DDR IP seems to fail its initialization/calibration :
- local_init_done, local_ready, ctl_cal_fail, ctl_cal_success... are all at '0'.
Is it possible to simulate ddr calibration ? How can I pass this step and get local_ready asserted ?
Thanks.
发表于 2012-1-5 15:50:33 | 显示全部楼层
check your tb first
发表于 2012-1-16 14:48:57 | 显示全部楼层
ftjfykgyuh
GMT+8, 2025-12-21 23:33 , Processed in 0.012405 second(s), 4 queries , Gzip On, Redis On.
