查看: 3786|回复: 3
[求助] ads2009u1 32-bit linux install error
发表于 2012-1-5 11:33:22 | 显示全部楼层 |阅读模式
I'm trying to install the ads2009u1 for linux but there are some errors shown below.
[13]: .[72]: .[7]: .: line 27: lsb_release: not found
aglmstat: error while loading shared libraries: libagsl.so: cannot enable executable stack as shared object requires: Permission denied
hpeesofde: error while loading shared libraries: libagsl.so: cannot enable executable stack as shared object requires: Permission denied
Anybody help me out! Thank you very much.
 楼主| 发表于 2012-1-5 15:09:26 | 显示全部楼层
Bye the way, I try to install ads2009U1 on Fedora15 and the libmotif3 can't be installed on Fedora15.
发表于 2012-5-7 19:01:52 | 显示全部楼层
缺库文件了嘛
 楼主| 发表于 2012-11-22 06:42:49 | 显示全部楼层
OK, ads2009u1 can't support the Fedora platform.
GMT+8, 2025-12-12 04:08 , Processed in 0.018205 second(s), 6 queries , Gzip On, Redis On.
