查看: 2549|回复: 2
[原创] 一个东西,随便看看
发表于 2011-12-28 15:24:33 | 显示全部楼层 |阅读模式
# include"recognition.h"
extern xdata unsigned int Coord_Buf[8];
typedef struct CoordSift {
unsigned int  x;             // x 坐标
unsigned int  y;             // y 坐标
unsigned char xym;           // xy 差和
unsigned char channel;       //
CoordSift CoordSiftA {
unsigned int  x = 0;
unsigned int  y = 0;
unsigned int  xym = 0;
unsigned char channel = 0;
CoordSift CoordSiftB {
unsigned int  x = 0;
unsigned int  y = 0;
void CoordRank(unsigned char len)
    unsigned char  i;
       switch(len)
     case 1  :  if(CoordSiftB.channel == 0)
          CoordSiftA.channel  = 8;
       CoordSiftB.channel  = 0;
       else if(CoordSiftA.channel == 0)
            CoordSiftA.channel  = 0;
          CoordSiftB.channel  = 8;
       else
           if(CoordSiftA.x  >  Coord_Buf[0])
            CoordSiftA.xym  = CoordSiftA.x - Coord_Buf[0];
                       else
              CoordSiftA.xym  = Coord_Buf[0] - CoordSiftA.x;
           if(CoordSiftA.y  >  Coord_Buf[1])
            CoordSiftA.xym  += CoordSiftA.y - Coord_Buf[1];
                       else
              CoordSiftA.xym  += Coord_Buf[1] - CoordSiftA.x;
           if(CoordSiftB.x  >  Coord_Buf[0])
            CoordSiftB.xym  = CoordSiftB.x - Coord_Buf[0];
                       else
              CoordSiftB.xym  = Coord_Buf[0] - CoordSiftB.x;
            if(CoordSiftB.y  >  Coord_Buf[1])
            CoordSiftB.xym  += CoordSiftB.y - Coord_Buf[1];
                        else
              CoordSiftB.xym  += Coord_Buf[1] - CoordSiftB.x;
                        if(CoordSiftB.xym  > CoordSiftA.xym )
                        else
       if(CoordSiftA.channel == 8)
            CoordSiftA.x = Coord_Buf[0];
            CoordSiftA.y = Coord_Buf[1];
            CoordSiftB.x = 0;
            CoordSiftB.y = 0;
                   else
            CoordSiftA.x = 0;
            CoordSiftA.y = 0;
      CoordSiftB.x = Coord_Buf[0];
            CoordSiftB.y = Coord_Buf[1];
    break;
  case 2  :   if((CoordSiftB.x << 1) > (Coord_Buf[0] + Coord_Buf[2]))
            CoordSiftA.channel  = 1;
            CoordSiftB.channel  = 4;
     else
            CoordSiftB.channel  = 1;
            CoordSiftA.channel  = 4;
       if(CoordSiftA.channel == 1)
          CoordSiftB.x = Coord_Buf[2];
             CoordSiftB.y = Coord_Buf[3];
                   else
             CoordSiftA.x = Coord_Buf[2];
             CoordSiftA.y = Coord_Buf[3];
    break;
  case 3  :   if(CoordSiftB.x > Coord_Buf[2])   //
     else
          CoordSiftB.x = Coord_Buf[6];
             CoordSiftB.y = Coord_Buf[7];
                   else
             CoordSiftA.x = Coord_Buf[6];
             CoordSiftA.y = Coord_Buf[7];
    break;
  case 4  :  if(CoordSiftA.channel | CoordSiftB.channel == 8)    // 1 -> 2
          CoordSiftB.xym  = 0xffff;
       for(i = 0; i < 4; i++)
                    if(CoordSiftA.x  >  Coord_Buf[i<<1])
                     CoordSiftA.xym  = CoordSiftA.x - Coord_Buf[i<<1];
                                else
                        CoordSiftA.xym  = Coord_Buf[i<<1] - CoordSiftA.x;
                    if(CoordSiftA.y  >  Coord_Buf[i<<1 + 1])
                     CoordSiftA.xym  += CoordSiftA.y - Coord_Buf[i<<1 + 1];
                                else
                        CoordSiftA.xym  += Coord_Buf[i<<1 + 1] - CoordSiftA.x;
                                if(CoordSiftA.xym < CoordSiftB.xym)
            CoordSiftB.xym     = CoordSiftA.xym;
         CoordSiftA.channel = i;
      else
          CoordSiftA.xym  = 0xffff;
                    if(CoordSiftB.x  >  Coord_Buf[i<<1])
                     CoordSiftB.xym  = CoordSiftB.x - Coord_Buf[i<<1];
                                else
                        CoordSiftB.xym  = Coord_Buf[i<<1] - CoordSiftB.x;
                    if(CoordSiftB.y  >  Coord_Buf[i<<1 + 1])
                     CoordSiftB.xym  += CoordSiftB.y - Coord_Buf[i<<1 + 1];
                                else
                        CoordSiftB.xym  += Coord_Buf[i<<1 + 1] - CoordSiftB.x;
                                if(CoordSiftB.xym < CoordSiftA.xym)
            CoordSiftA.xym     = CoordSiftB.xym;
         CoordSiftB.channel = i;
       else if(CoordSiftA.channel | CoordSiftB.channel != 0)    // 2 -> 2
                           if(inverterA == 1)
          switch(CoordSiftA.channel)
              case 1 :  CoordSiftA.channel  = 2;
                              CoordSiftB.channel  = 3;
                      break;
        case 2 :  CoordSiftA.channel  = 1;
          break;
        case 3 :  CoordSiftA.channel  = 4;
          break;
        case 4 :  CoordSiftA.channel  = 3;
                              CoordSiftB.channel  = 2;
          break;
                                default: ;
                           if(inverterB == 1)
              case 1 :  CoordSiftA.channel  = 3;
                      break;
        case 2 :  CoordSiftA.channel  = 4;
          break;
        case 3 :  CoordSiftA.channel  = 1;
          break;
        case 4 :  CoordSiftA.channel  = 2;
          break;
                                default: ;
       else   // 0 -> 2
      case 1 :  CoordSiftA.x = Coord_Buf[0];
              break;
         case 2 :  CoordSiftA.x = Coord_Buf[2];
                   CoordSiftB.x = Coord_Buf[4];
                      CoordSiftB.y = Coord_Buf[5];
           break;
         case 3 :  CoordSiftA.x = Coord_Buf[4];
                      CoordSiftA.y = Coord_Buf[5];
           break;
         case 4 :  CoordSiftA.x = Coord_Buf[6];
           break;
                       default: ;
        break;
        default : ;
发表于 2012-2-2 09:15:07 | 显示全部楼层
什么东东
发表于 2014-12-3 11:46:58 | 显示全部楼层
恩 隨便看看  也頂一下
GMT+8, 2025-9-13 04:07 , Processed in 0.014628 second(s), 5 queries , Gzip On, Redis On.
