查看: 2516|回复: 0
Question about performance of ICC Zroute
发表于 2011-12-22 11:20:46 | 显示全部楼层 |阅读模式
I have a question about the performance of ICC Zroute:It seems doesn't have a good result for ICC Zroute doing tsmc 0.25um process.
User must  use classical route to do the final routing , otherwise the chip can not be clean.
Does anyone have same experience on this situation? and  then give me input to get better solution.
My tcl commands as following:
route_zrt_group -all_clock_nets \
  -max_detail_route_iterations  50
route_zrt_auto \
  -max_detail_route_iterations  100
route_zrt_detail -incremental true -max_number_iterations 200
route_search_repair \
  -rerun_drc  \
  -loop 300 \
  -trim_antenna_of_user_wires
GMT+8, 2025-12-17 09:30 , Processed in 0.021689 second(s), 6 queries , Gzip On, Redis On.
