查看: 8966|回复: 0
[求助] formality undriven signal cut-point
发表于 2011-12-21 11:03:56 | 显示全部楼层 |阅读模式
Hi, all
plz help with the following formality troubles
In my design, I have some empty ports(which are finally not used, and are kept given the current project stage),
however when doing formal-check(REF: synthesis netlist, IMP: route netlist), troubles are issued.
eg. the empty port "PORT_0" are matched point and are verified, however the following unmatched points are issued
Ref Und REF:/WORK/design/PORT_O(1 reference, 0 implementation)
do I need to care this, or how to fix it?
thanks in advance
regards,
henry
GMT+8, 2025-12-27 06:31 , Processed in 0.016821 second(s), 6 queries , Gzip On, Redis On.
