查看: 12319|回复: 10
[讨论] 请问使用laker时在layer table 上面shift+鼠标右键有几种用法?
发表于 2011-12-15 11:37:32 | 显示全部楼层 |阅读模式
如题,
发表于 2011-12-15 14:34:41 | 显示全部楼层
laker没有用过,帮顶
发表于 2011-12-15 21:08:53 | 显示全部楼层
没有明白是什么意思。图形旋转吧
发表于 2011-12-15 21:44:51 | 显示全部楼层
如果只对单一 layer table 进行shift+右键操作,应该有三种:sel=0,vis=1(有两种在sel上一次,在vis上一次);sel=1,vis=1;sel=0,vis=0;
 楼主| 发表于 2011-12-16 13:40:02 | 显示全部楼层
thank cxl666, 请教laker的鼠标设置在哪个文件里呢?
 楼主| 发表于 2011-12-19 11:08:49 | 显示全部楼层
我顶!~
发表于 2011-12-19 13:21:14 | 显示全部楼层
快捷键设置在/Laker/etc/leoDsgWnd.menu里,右键设置如下,可以自行修改Menu RightClickCommandMenu
    "Move"                          f.exec          "LEODSGMove"
    "Copy"                          f.exec          "LEODSGCopy"
    "Delete"                        f.exec          "LEODSGDelete"
    "Attribute..."                  f.exec          "LEODSGAttribute"
    "Window Check DRC"              f.exec          "LEODSGOnlineCheckDRC"
    "Clear LiveDRC Error Marker"    f.exec          "LEODSGClearRuleDrvMark"
# If you bind the "up" or "down" button to a command, it will be invoked
# either on the "up" or "down" button, and also on the "click" event.
# But, if you bind the "click" event to a command, it will be invoked
# only on the "click" event and won't be invoked on the "up" or "down" event.
Buttons turboButtonBinding
#<Btn1Down>
#<Btn1Click2>
#<Btn1Up>
发表于 2011-12-19 13:30:00 | 显示全部楼层
学习了!!!
发表于 2012-2-29 16:54:31 | 显示全部楼层
没用过,帮顶顶
发表于 2012-2-29 16:55:52 | 显示全部楼层
强人多啊
站长推荐 上一条 /3 下一条
GMT+8, 2025-9-11 07:36 , Processed in 0.020588 second(s), 5 queries , Gzip On, Redis On.
