查看: 9833|回复: 17
[资料] mini-LVDS Interface Specification (TI)
发表于 2011-12-13 17:27:34 | 显示全部楼层 |阅读模式
ABSTRACT
The trend towards higher and higher resolutions in flat panel displays, particularly LCD
panels, is pushing the capabilities of conventional interfaces towards display drivers to the
limit. The aggregate bandwidth requirement for state-of-the art displays (e.g. UXGA and
QXGA) is already in the range of 5 Gbps and will increase. This necessitates a large number
of connections between the timing controller and the display drivers, with the result being that
the interconnect becomes the bottleneck in further reduction of display size. EMI generation
by this wide interconnect is another problem. The conventional parallel CMOS interface,
which has served well for low resolution displays in the past, is no longer a viable solution for
today’s displays.
The mini-LVDS is a high speed serial interface that solves these problems. This specification
describes the electrical and logical features of this interface. The mini-LVDS offers a low EMI,
high bandwidth interface towards display drivers, which is particularly well-suited for TFT
LCD panel column drivers.
Contents
1 Scope . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3
2 Overview . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3
3 DC Electrical Specifications . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6
3.1 Transmission Line Impedance . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6
3.2 Termination . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6
3.3 mini-LVDS Transmitter Output-Signal Levels . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6
3.4 mini-LVDS Receiver Specifications . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7
3.5 TP1 and POL Output Specifications . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7
3.6 TP1 and POL Input Specifications . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7
4 Differential Signal Timing Specifications . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8
4.1 mini-LVDS Transmitter Timing Specifications . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8
4.2 Receiver AC Specifications . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8
5 Control Signal Timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9
5.1 Reset Pulse . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9
5.2 Last Display Data and TP1 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10
5.3 Relationship Between POL and TP1 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
6 Logical Interface . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
6.1 Overview and Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
6.2 Data Sequence . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
6.2.1 6-Bit Data, Three Pairs . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12
6.2.2 6-Bit Data, Four Pairs . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13
6.2.3 6-Bit Data, Five Pairs . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14
6.2.4 6-Bit Data, Six Pairs . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15
6.2.5 8-Bit Data, Three Pairs . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16
6.2.6 8-Bit Data, Four Pairs . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16
6.2.7 8-Bit Data, Five Pairs . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17
6.2.8 8-Bit Data, Six Pairs . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 18
mini-LVDS Interface Specification.pdf
323.33 KB, 下载次数: 298 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2011-12-16 11:18:26 | 显示全部楼层
dow lo@d to see
thanks~
发表于 2012-1-12 18:17:18 | 显示全部楼层
thxy brother.
发表于 2012-4-6 12:26:41 | 显示全部楼层
非常感谢!
发表于 2012-4-25 10:14:45 | 显示全部楼层
ding ding ding ding
发表于 2012-9-1 15:52:32 | 显示全部楼层
TITITI
发表于 2012-9-10 12:49:33 | 显示全部楼层
TITITI
发表于 2013-3-13 09:48:01 | 显示全部楼层
好东西, 谢谢分享啊
发表于 2013-3-24 10:59:24 | 显示全部楼层
非常感谢
谢谢分享
发表于 2013-5-15 11:00:21 | 显示全部楼层
很有用的資料, 可以下載來研究一下, 謝謝!!
GMT+8, 2025-9-17 05:32 , Processed in 0.023094 second(s), 5 queries , Gzip On, Redis On.
