查看: 7133|回复: 11
[求助] Astro中design setup/启动Floorplan时failing to get unit's CellID
发表于 2011-12-12 20:47:31 | 显示全部楼层 |阅读模式
如题,Astro中design setup/启动Floorplan时failing to get unit's CellID求高人解答呀!
发表于 2011-12-12 22:15:16 | 显示全部楼层
std cell库有问题,tar解压不要在windos下,要在linux系统下解压
发表于 2011-12-14 09:20:28 | 显示全部楼层
是 unitTile:1 这种单元的问题吧,
:1 是milkway的版本号,就是这样命名的
发表于 2011-12-14 09:49:46 | 显示全部楼层
回复 1# 黄金虾仁炒饭
ERROR: Fail to Run Floorplanner Due to Failing to Get Unit's CellId
Question:
I'm trying to floorplan an I/O ring. The following processes work fine,
with no errors: reading Verilog into Astro, expanding the netlist, binding
the netlist, and then defining the power pads and nets.
However, when I open the cell view that is created and run the axgPlanner
command, I get the following error message:
Fatal/Error Messages:
Fail to run Floorplanner due to failing to get unit's CellId!
Cannot perform requested operation.
Why do I get this error message? How do I resolve the problem?
Answer:
The error message indicates that the floorplanner is unable to read the
unitTile cell. This is because the unitTile cell is missing or its place
and route boundary (PR boundary) does not exist.
For information about creating the place and route boundary, see the Milkyway
Environment Data Preparation User Guide.
发表于 2012-2-27 14:59:12 | 显示全部楼层
你好,我也遇到了相同的问题,现在已经解决了,应该是你的ref lib没有在linux下解压缩,在windows下面解压后拷到linux就会出现这个错误- -血的教训,我也头疼了半天才搞定
发表于 2012-6-16 21:29:55 | 显示全部楼层
感谢大神们的答案,小弟受教了
发表于 2012-6-17 02:11:00 | 显示全部楼层
楼上各位都是正解,简单的说就是没解压成功,办法就是把库再解压一遍。of course要在linux下解压哦亲~
发表于 2012-6-20 11:00:58 | 显示全部楼层
小弟受教了
发表于 2012-6-30 22:09:19 | 显示全部楼层
thanks   a  lot !
发表于 2014-6-22 20:24:06 | 显示全部楼层
明白了,好东西 啊
GMT+8, 2025-11-30 18:12 , Processed in 0.022134 second(s), 6 queries , Gzip On, Redis On.
