楼主: cxl666
Novas201110可用
 楼主| 发表于 2011-12-28 15:21:13 | 显示全部楼层
回复 20# jacksonzh
    看1楼帖子
发表于 2011-12-28 17:19:58 | 显示全部楼层
怎么样patch,那些变量在那个文件里改?
发表于 2011-12-28 18:10:34 | 显示全部楼层
出现如下错误啊:
bash: patch_novas201110_32: command not found
[root@john bin]# ./patch_novas201110_32
[total hits/matching patterns/non-matching patterns]
1 files checked, 0 changed.
 楼主| 发表于 2011-12-28 21:51:16 | 显示全部楼层
回复 23# jacksonzh
    放在根目录下,文件属性设置为可执行,用root权限进行。
发表于 2011-12-29 09:38:13 | 显示全部楼层
放到根目录下现如下问题,增加执行权限
,系统为centos 6
error: no such file or dir: novas
note : if this is a pattern, say -pat novas
1 errors occurred.
error: no such file or dir: aliasextract
note : if this is a pattern, say -pat aliasextract
1 errors occurred.
error: no such file or dir: fsdbreport
note : if this is a pattern, say -pat fsdbreport
1 errors occurred.
error: no such file or dir: libls
note : if this is a pattern, say -pat libls
1 errors occurred.
error: no such file or dir: nAnalyzer
note : if this is a pattern, say -pat nAnalyzer
1 errors occurred.
error: no such file or dir: nce2report
note : if this is a pattern, say -pat nce2report
1 errors occurred.
error: no such file or dir: netlistcom
note : if this is a pattern, say -pat netlistcom
1 errors occurred.
error: no such file or dir: vericom
note : if this is a pattern, say -pat vericom
1 errors occurred.
放到/novas/bin目录下后,增加执行权限,出现如下情况:
1 errors occurred.
1 errors occurred.
1 errors occurred.
1 errors occurred.
1 errors occurred.
1 errors occurred.
1 errors occurred.
1 errors occurred.
发表于 2011-12-29 09:55:22 | 显示全部楼层
呼唤cxl666,感谢你的支持!
 楼主| 发表于 2011-12-29 11:26:12 | 显示全部楼层
回复 26# jacksonzh
我是在安装在redhat系统下的,centos 6没装过,放在根目录下执行,从你报的错应该是没有替换成功,你把后面几个patch命令行改为类似./sfk rep XXX -yes -pat 试试。
发表于 2011-12-29 13:44:33 | 显示全部楼层
好像很贵的样子,不过试一下吧
发表于 2011-12-29 22:11:30 | 显示全部楼层
centos 5.6同样问题,是不是系统的问题阿!
 楼主| 发表于 2011-12-30 09:10:27 | 显示全部楼层
回复 29# jacksonzh
    也许吧,没用那个系统装过EDA软件。
GMT+8, 2025-11-8 09:59 , Processed in 0.017481 second(s), 3 queries , Gzip On, Redis On.
