查看: 16743|回复: 6
[求助] illegal 'timescale for module反标后仿真
发表于 2011-12-8 10:48:45 | 显示全部楼层 |阅读模式
求助各位前辈,在反标sdf后进行vcs仿真,提示error:illegal 'timescale for module,module"AN2D0" has 'timescale but previous module do not,请问这个是什么意思呢?怎么解决呢?谢谢各位啦!
 楼主| 发表于 2011-12-9 08:58:14 | 显示全部楼层
自己顶一个
发表于 2011-12-21 14:20:16 | 显示全部楼层
你看看网表里"AN2D0" 的描述里面有一个timescale,但是你其他的module没有定义timescale
发表于 2012-1-3 15:33:56 | 显示全部楼层
nc里面-override_timescale -timescale 1ns/1ps
就是把原有的timescale全部改写为1ns/1ps
vcs里面应该也可以类似的处理,看一下UG
发表于 2013-2-26 12:27:57 | 显示全部楼层
nc是什么东东?
发表于 2015-9-23 21:51:05 | 显示全部楼层
楼主,这个问题解决了没,怎么解决的
发表于 2015-9-28 15:39:44 | 显示全部楼层
solvnet:
Question:
What does VCS  "Error-[ITSFM] Illegal `timescale for module" mean?
Answer:
VCS/VCSMX will generate a compile error "Error-[ITSFM] Illegal `timescale for module"
if the first Verilog source file passed to the vcs compile command does not have a
`timescale directive and subsequent Verilog sources do.
To overcome this error, there are 3 things the user can do:
1) Reorder the source files passed to VCS (Refer to solvnet article DOC ID
   900543 for information on how timescales are defined and used by simulators).
2) Use the VCS' -timescale=base/precision Verilog compile option
   where you specify base and precision. Ex:
     % vcs no_timescale.v file_with_timescale.v -timescale=1ns/10ps
    -timescale=base/precision will use the timescale provided on the compile
    command for the first Verilog file passed to VCS IF there is no explicit
    `timescale directive in the first Verilog source file passed.
3) Use VCS' Verilog compile option -override_timescale=base/resolution option.
   This will override all timescales (including explicit `timescale directives)
   and have VCS use the timecale specified by this option. Ex:
     % vcs no_timescale.v file_with_timescale.v -override_timescale=1ns/1ns
   If file_with_timescale.v has a `timescale 1ns/10ps directive, this will be
   overriden by VCS and VCS will use 1ns/1ns timescale for ALL Verilog modules.
回复 支持 4 反对 0
GMT+8, 2025-12-24 18:58 , Processed in 0.022627 second(s), 6 queries , Gzip On, Redis On.
