楼主: huangjw1
[资料] 最近发表的一篇LDO的论文
发表于 2011-12-21 23:15:32 | 显示全部楼层
3QQQQQQQQQ
发表于 2011-12-26 08:56:19 | 显示全部楼层
谢谢谢谢
发表于 2011-12-26 10:39:24 | 显示全部楼层
Abstract: This paper presents a 200 mA low-dropout (LDO) linear regulator using two modified techniques for
frequency compensation. One technique is that the error amplifier uses a common source stage with variable load,
which is controlled by the output current, is served as the second stage for a stable frequency response. The other
technique is that the LDO uses a pole-zero tracking compensation technique at the error amplifier to achieve a
good frequency response. The proposed circuit was fabricated and tested in HJTC 0.18 m CMOS technology.
The designed LDO linear regulator works under the input voltage of 2.8–5 V and provides up to 200 mA load
current for an output voltage of 1.8 V. The total error of the output voltage due to line and load variation is less than
0.015%. The LDO die area is 630  550 m2 and the quiescent current is 130 A.
发表于 2011-12-26 10:40:27 | 显示全部楼层
Year         2007Œ5�         2008Œ7�         2009Œ11�         2011Œ6�         This work
Technology (m)         0.35         0.35         0.18         0.35         0.18
Chip area (mm2/         0.264         0.409         —         0.463         0.346
Input voltage (V)         2–5.5         2–3.6         3–5.5         2.2–3.3         2.8–5
Output voltage (V)         1.8         1.8         1.8         2         1.8
Load regulation (mV/mA)         0.17         0.7         0.448         0.3         0.15
Settling (&#22;s)         —         5 (0–100 mA)         2 (1–100 mA)         8         < 50 (1–200 mA)
Maximum output current (mA)         200         150         125         200         200
Quiescent current (&#22;A)         340         27         150         60         130
发表于 2012-3-27 11:13:31 | 显示全部楼层
gooooooooooooooooooooood
发表于 2012-5-12 10:06:27 | 显示全部楼层
谢谢啦!
GMT+8, 2025-12-19 17:16 , Processed in 0.018810 second(s), 3 queries , Gzip On, Redis On.
