查看: 10282|回复: 14
[求助] 求IEEE 文章,先谢了!
发表于 2011-12-3 13:51:24 | 显示全部楼层 |阅读模式
http://ieeexplore.ieee.org/xpl/freeabs_all.jsp?arnumber=1696188
A Micropower Chopper-Stabilized Operational Amplifier using a SC Notch Filter with Synchronous Integration inside the ContinuousTime Signal Path
[size=0.915em]Access The Full Text
SIGN IN:Full text access may be available with your subscription
Forgot Username/Password?Athens/Shibboleth Sign In
Burt, R.;   Zhang, J.;
Texas Instruments, Tucson, AZ
This paper appears in: Solid-State Circuits Conference, 2006. ISSCC 2006. Digest of Technical Papers. IEEE International
Issue Date: 6-9 Feb. 2006
On page(s): 1388 - 1397
ISSN: 0193-6530
Print ISBN: 1-4244-0079-1
INSPEC Accession Number: 9122526
Digital Object Identifier: 10.1109/ISSCC.2006.1696188
Date of Current Version: 18 九月 2006
[size=1.085em]ABSTRACT
A micropower chopper-stabilized opamp uses an SC notch filter with synchronous integration inside the CT signal path to eliminate chopping noise. Characteristics include rail-to-rail I/O, 15muA supply current at 1.8 to 5.5V, 2muV offset, 55nV/radicHz noise, 350kHz GBW, and a chopping frequency of 125kHz. The die area is 0.7mm2using 0.6mum CMOS
发表于 2011-12-3 23:42:23 | 显示全部楼层
A Micropower Chopper-Stabilized Operational.rar (1.64 MB , 下载次数: 116 ) 回复 1# jluhzw
    希望对你有所帮助
发表于 2011-12-4 02:02:13 | 显示全部楼层
就這篇囉...
abbr_cda8e730be1951c24d2a895b254ab831.pdf (511.41 KB , 下载次数: 125 )
再加一篇發表在JSSC 的 Journal
abbr_715f40f56709442326225661995a8b06.pdf (1.26 MB , 下载次数: 131 )
发表于 2011-12-5 22:20:58 | 显示全部楼层
正差这本书非常感谢
 楼主| 发表于 2011-12-8 17:54:24 | 显示全部楼层
谢谢楼上各位!
发表于 2012-12-20 17:20:44 | 显示全部楼层
为什么我的帖子不见了?
发表于 2012-12-20 17:23:28 | 显示全部楼层
没有钱下载了
发表于 2020-8-12 03:34:40 | 显示全部楼层
Thanks!!!
发表于 2020-11-19 16:06:58 | 显示全部楼层
Good!
发表于 2021-11-15 11:07:16 | 显示全部楼层
谢谢
GMT+8, 2025-12-28 11:47 , Processed in 0.024927 second(s), 7 queries , Gzip On, Redis On.
