查看: 9876|回复: 12
[求助] smic13_mmrf库varctor仿真遇到问题
发表于 2011-11-29 21:33:08 | 显示全部楼层 |阅读模式
大家好,我用IC614 仿真pvar_ckt这个cell的时候报错,提示信息如下:
Loading /home/seles/opt/cadence/mmsim720/tools.lnx86/cmi/lib/5.0/libinfineon_sh.so ...
Loading /home/seles/opt/cadence/mmsim720/tools.lnx86/cmi/lib/5.0/libphilips_sh.so ...
Loading /home/seles/opt/cadence/mmsim720/tools.lnx86/cmi/lib/5.0/libsparam_sh.so ...
Loading /home/seles/opt/cadence/mmsim720/tools.lnx86/cmi/lib/5.0/libstmodels_sh.so ...
Auto-loading AHDL component.
Finished loading AHDL component in 0 s (elapsed).
Installed AHDL simulation interface.
Opening directory input.ahdlSimDB/ (775)
Opening directory input.ahdlSimDB/8318_smic13mmrf_1233____models_spectre_gc_rf.va.aigg_hdl.ahdlcmi/ (775)
Opening directory input.ahdlSimDB/8318_smic13mmrf_1233____models_spectre_gc_rf.va.aigg_hdl.ahdlcmi/Linux2.6.32-36-generic+gcc/ (775)
Compiling ahdlcmi module library.
Error found by spectre during AHDL read-in.
    ERROR (VACOMP-1008): Cannot compile ahdlcmi module library. Check the log file input.ahdlSimDB/8318_smic13mmrf_1233____models_spectre_gc_rf.va.aigg_hdl.ahdlcmi/Linux2.6.32-36-generic+gcc/ for details. If the compiler ran out of memory, use 'setenv CDS_CMI_COMPLEVEL 0', and try again. If the reason for the failure was a syntax error, contact your Cadence Customer Support representative with the netlist, log files, behavioral model files, and any other information that can help identify the problem.
    ERROR (VACOMP-1697): "parameter real (*integer inherited_mfactor; *) m=1;<<--? "
        "Internal (bsource)", line 382: Attempting to redefine identifier 'm'. Remove the extra definition or use a different identifier.
spectre terminated prematurely due to fatal error.
但是其他cell(mos管和电感都可以正常仿真)
不知道有没有其他人遇到过这样的问题,请高手不吝赐教,多谢
 楼主| 发表于 2011-12-2 23:20:30 | 显示全部楼层
解决了,要把系统默认shell改成bash.....
发表于 2012-3-17 15:36:05 | 显示全部楼层
回复 2# seles314
    楼主可否详细讲解一下呢 ,碰到了同样的问题!
 楼主| 发表于 2012-3-18 23:20:00 | 显示全部楼层
sudo dpkg-reconfigure dash
然后选择no
发表于 2012-3-30 00:44:58 | 显示全部楼层
回复 4# seles314
    谢谢你的方法
发表于 2012-3-30 22:08:17 | 显示全部楼层
It works. Thanks a lot.
发表于 2012-6-21 19:34:45 | 显示全部楼层
centos默认是BASH,也报相同的错,是什么原因啊?
发表于 2012-8-6 13:26:20 | 显示全部楼层
?不太明白
没有找到这个命令。。。
发表于 2012-8-8 16:12:45 | 显示全部楼层
本身用的csh,也有这个问题。。
发表于 2013-11-17 12:42:44 | 显示全部楼层
回复 7# alexsss
   请问这个问题解决了吗?我也遇到相同的问题
GMT+8, 2025-12-14 00:15 , Processed in 0.035294 second(s), 6 queries , Gzip On, Redis On.
