楼主: baiyawen
[原创] 半导体生产视频资料一-硅片生产和芯片制造(重新压缩)
发表于 2014-12-30 17:25:23 | 显示全部楼层
回复 1# baiyawen
发表于 2014-12-30 17:26:43 | 显示全部楼层
回复 1# baiyawen
发表于 2015-1-6 13:55:37 | 显示全部楼层
怎么下载的时候顺序对不上啊
发表于 2015-1-6 13:57:07 | 显示全部楼层
可以了
发表于 2015-1-16 14:35:01 | 显示全部楼层
顶一下
发表于 2015-2-5 19:20:46 | 显示全部楼层
顶顶顶顶顶顶顶顶顶顶顶顶得到的得到的得到的
发表于 2015-2-5 19:22:44 | 显示全部楼层
发表于 2015-2-5 19:23:25 | 显示全部楼层
TSMC More-than-Moore technologies provide additional values
Recently, the global semiconductor industry is seeing a new trend called “More-than-Moore” (MtM), where added values to devices are provided by incorporating functionalities that do not necessarily scale according to Moore's Law.
Moore's Law states that the number of transistors on a chip will double every 18 months. However, due to the physical properties of the chip, Moore's Law will one day face its ultimate limitation. While packing more transistors on a chip to add power and performance is still a key focus, developing novel MtM technologies on top of the Moore's Law technologies to provide further values to semiconductor chips has also become a more important issue.
That's what gave rise to MtM, which is symbiotic with Moore's Law and allows non-digital functionalities to migrate from the system board-level into the package (SiP) or onto the chip (SoC).
More-than-Moore technologies cover a wide range of fields. For example, MEMS applications include sensors, actuators and ink jet printers. RF CMOS applications include Bluetooth, GPS and Wi-Fi. CMOS image sensors are found in most digital cameras. High voltage drivers are used to power LED lights. These applications add value to computing and memory devices that are made from the traditional Moore's Law technology.
Here at TSMC, we have the technical capability and capacity to satisfy customers' wide-range needs. Adding values to customers' products has, and always will be, our top priority
发表于 2015-2-5 19:27:25 | 显示全部楼层
发表于 2015-2-6 23:42:21 | 显示全部楼层
好东西!
GMT+8, 2025-12-16 07:47 , Processed in 0.019845 second(s), 3 queries , Gzip On, Redis On.
