楼主: ic_qiand
[2011-11-1][Mentor][Calibre X86 X64 Doc][2011.2_16.14][原创] Calibre一贴搞定...
发表于 2012-12-23 21:51:00 | 显示全部楼层
回帖赚钱
发表于 2012-12-25 14:17:03 | 显示全部楼层
thanks
发表于 2012-12-25 14:17:42 | 显示全部楼层
thanks
发表于 2012-12-25 15:08:21 | 显示全部楼层
非常感谢楼主
发表于 2012-12-26 09:45:15 | 显示全部楼层
Hi,你好,我在安装calibre(系统为centos)时,按照步骤产生了license.dat,然后下载了patch2011以及sfk,在运行./patch时遇到下面的error,请问为什么?
Linux machine : localhost
: Command not found.
set: Variable name must begin with a letter.
[total hits/matching patterns/non-matching patterns]
78% shared/lib/libcfiel_6error: failed to read+write: sfk - skipping
6617 files checked, 0 changed.
1 errors occurred.
发表于 2012-12-29 23:14:09 | 显示全部楼层
回复 4# frederick_gu
    谢谢!!!!
发表于 2012-12-31 10:49:48 | 显示全部楼层
[Cadence@localhost ~]$ calibre
ERROR: Could not invoke /usr/local/mentor/calibre2011/x86_cal_2011.2_34.26/pkgs/icv/pvt/calibre
[Cadence@localhost ~]$ 10:39:17 (lmgrd) Still trying...
10:39:35 (lmgrd) Still trying...
10:39:53 (lmgrd) Still trying...
10:40:11 (lmgrd) Still trying...
10:40:29 (lmgrd) Still trying...
10:40:47 (lmgrd) Still trying...
10:41:05 (lmgrd) Still trying...
10:41:23 (lmgrd) Still trying...
10:41:41 (lmgrd) Still trying...
10:41:56 (lmgrd) Failed to open the TCP port number in the license.
发表于 2012-12-31 10:50:44 | 显示全部楼层
请问这是为什么???
发表于 2012-12-31 10:51:38 | 显示全部楼层
小弟在等!!!求回复
发表于 2013-1-3 02:33:27 | 显示全部楼层
good share.
GMT+8, 2025-10-27 17:32 , Processed in 0.020556 second(s), 5 queries , Gzip On, Redis On.
