查看: 5060|回复: 1
[讨论] 跑DFT脚本插链后DRC遇到一个错误
发表于 2011-10-25 19:48:54 | 显示全部楼层 |阅读模式
insert_dft
dft_drc
提示 如下
Error:chain 1 blocked at DFT gate U_PAD/u_pad_nf_data_0 after tracing 4609cells;
Error:chain 2 blocked at DFT gate U_PAD/u_pad_nf_data_0 after tracing 4609 cells;
Error:chain 3 blocked at DFT gate U_PAD/u_pad_nf_data_0 after tracing 4609 cells;
Error:chain 4 blocked at DFT gate U_PAD/u_pad_nf_data_0 after tracing 4609 cells;
Error:chain 5 blocked at DFT gate U_PAD/u_pad_nf_data_0 after tracing 4609 cells;
Error:chain 6 blocked at DFT gate U_PAD/u_pad_nf_data_0 after tracing 4609 cells;
Error:chain 7 blocked at DFT gate U_PAD/u_pad_nf_data_0 after tracing 4609 cells;
Error:chain 8 blocked at DFT gate U_PAD/u_pad_nf_data_0 after tracing 4609 cells;
Error:chain 9 blocked at DFT gate U_PAD/u_pad_nf_data_0 after tracing 4609 cells;
Error:chain 10 blocked at DFT gate U_PAD/u_pad_nf_data_0 after tracing 4609 cells;
每条链都是 4610 cells
怎么解决这个问题呢?
发表于 2012-2-22 03:17:42 | 显示全部楼层
Blocked by Bi-direction Pad
GMT+8, 2025-12-30 17:52 , Processed in 0.015603 second(s), 5 queries , Gzip On, Redis On.
