查看: 5366|回复: 7
[招聘] 凌力尔特中国研发中心招聘LAYOUT工程师
发表于 2011-10-14 11:28:17 | 显示全部楼层 |阅读模式
凌力尔特中国研发中心招聘LAYOUT工程师,工作地点在杭州。可通过Linear官方网站投递简历,也可将简历(中英文,PDF格式)发至:boyuan_sh@yahoo.com
JD:
Position Type:        Full-Time Regular
Position Overview
Linear Technology Corporation is seeking an enthusiastic Mask Designer / Physical Layout Engineer in our Hangzhou, China Design Center.
We develop a wide range of high-performance power, analog, and mixed-signal ICs using our unique Bipolar, Bi-CMOS, and CMOS processes.   We compete in a wide range of markets including:
• DC/DC Converters
• High Resolution Data Conversion
• Interface Products
• Portable Power Management
• Hot Swap Controllers
• High Performance Amplifiers and References
• Automotive Electronics
Responsibilities include (but are not limited to):
• Layout schedule estimation.
• IC layout floor planning.
• Layout of analog and digital circuits.
• Cell level verification and parasitic extraction.
• Chip/Top level routing and interconnect.
• LVS and DRC checks using Cadence Dracula and Assura.
• Tape out/Stream out/PG.
Required Skills
The ideal candidate must have the following key requirements for this position:
• bachelor or master’s degree in Electrical Engineering.
• Three years or more of relevant IC layout experience.
• Strong background in analog layout.
• Familiarity with Cadence tools (Virtuoso, Layout XL, Assura, Dracula).
• Layout experience with bipolar, CMOS, and BiCMOS technologies.
• Working knowledge of Linux operating systems.
• Experience with full chip layout including PG to the mask shop.
• Knowledge of semiconductor device and fabrication principles is a plus.
• Ability to work independently.
• Great attention to detail, communication skills, well organized
 楼主| 发表于 2011-10-18 14:31:20 | 显示全部楼层
up for attention.
发表于 2011-10-19 23:46:31 | 显示全部楼层
linear tech在中国有研发中心?
发表于 2011-10-20 12:44:01 | 显示全部楼层
听说linear的模拟电路工程师在美国年薪10W美金和3—6月奖金,不知道layout工程师在中国待遇怎样
发表于 2011-10-20 12:48:24 | 显示全部楼层
招IC前端吗?
 楼主| 发表于 2011-11-16 09:10:57 | 显示全部楼层
Still valid.
发表于 2012-3-12 11:12:48 | 显示全部楼层
据说人很少,不知道有没有扩展的计划
发表于 2012-3-12 11:38:31 | 显示全部楼层
LT绝对一流的公司,利润在75%以上,只是国内有研发中心??估计只招layout的给美国那边的designer服务
GMT+8, 2025-11-1 17:19 , Processed in 0.029329 second(s), 5 queries , Gzip On, Redis On.
