FPGA Engineer
Responsibilities:
1.FPGA design verification. Porting ASIC code to FPGA platform, verify the whole design in FPGA system.
2.Lead the whole FPGA verification flow, include specification, coding, simulation, physical implementation board level
debugging.
3.Organize Coordinate the work of debug team.
4.Capability of making rapidly scheme/method to trace issue.
5.RTL module development to assist the verification on FPGA
Requirement:
1.MS in Electronic or Computer Science Engineering is required. Expert in FPGA operation theory.
2.More than 3 years experience in design verify on FPGA.
3.Project experience in mapping large scale, multi-million gate ASIC to multiple FPGAs
4.Architecture design flow Expert in Verilog or VHDL. Familiar with FPGA EDA tools, such as Synplify, ISE, QuartusII Expert
in Xilinx product.
5.Strong coding skills in Verilog/VHDL RTL.
6.Strong system bring up skills.
7.Experience in Chip system test.
8.Analyze the FPGA requirement, evaluate the resource the chip type in the design phase.
9.Familiar with SOC architecture OCP/AHB/APB.
10.Familiar with video system is preferable
11.The cidate is required to use the logic analyzer oscillator to debug in FPGA Design.
12.Outsting written verbal communication skills in English
13. Familiar with FPGA co-simulation is preferable
jobic_cn@126.com
DSP Architecture Engineer
Job Description:
1. Response for design architecture of video/image processing chip /or video/image processing IP based on understing of video
processing algorithm background knowledge of IC design verification. Architecture engineers not only design architecture,
but also need cooperate with algorithm designers, IC designers verification engineers.
2. Architecture design work includes mapping algorithm solution into hardware solution from following aspects:
a) Function partition of algorithm solution
b) Design Interface interface’s protocol design between IP block or sub-block
c) Control mechanism define, calculation logic evaluation, storage size bwidth evaluation based on cost, throughput,
3. Architecture designer is response for consider design’s cost which include die size, power consumption, rtl design
verification effort.
4. Architecture designer is response for give valuable feedback to algorithm designers to optimize their algorithm from
cost/performance’s view
5. Architecture designer is response for support accelerate IC implementation verification by proper architecture partition
modeling
Requirements
1. 2 - 3 (4 - 5 for senior) years experience in IC industry
2. IC design experience
a) RTL coding debugging skill
b) Familiar with IC develop tools, such as ModelSim, Debussy
3. Architecture design implementation experience of some of following aspects
a) calculation pipeline design
b) SRAM control
c) Typical bus protocol, OCP,
d) Familiar with DMA, DDR related topics
4. Video processing chip experience one of following aspects is nice to have:
a) Familiar with image processing or video processing algorithm solution
b) Familiar with video compression stard, such as: MPEG, H.264
jobic_cn@126.com
Sr. IC Engineer
1.This cidate should have video-processing background should be interesting in R&D on Video related technologies. Be able to
debug work with SW on AFE/VDC issues reported from customers.
2. IC/FPGA background. Be interesting in developing improving New IP try to detailed underst it.
3. With at least 5-years IP/Product R&D experience.
Job Description
RTL coding, new logic design, simulation, synthesis, debug on the FPGA platform.
Work closely with algorithm engineer to develop/debug new IP/product.
Work closely with system/SW engineer to verificate/validate new IP/product on FPGA/System platform.
Deliver design/verification/application documents.
Qualification Experience
-Very familiar with the Verilog HDL language
-Create the RTL architecture for the algorithm
-Very familiar with C C++
-Familiar with FPGA tool, ModelSim, Synplify.
-Familiar with the flow of the IC design.
Requirements:
- Bachelor/Master degree in electronic/computer engineering
- Demonstrated abilities in working independently
- Strong communication skills
jobic_cn@126.com
Sr./ DFT Engineer
Required:
1. Chip integration full chip synthesis.
2. Underst timing constraints timing sign off at chip level.
3. Familiar with DFT, including scan ion, ATPG generation, MBIST ion functional test pattern generation.
4. Can work with BE team, analog team third party to drive full chip P&R timing closure.
5. Familiar with synthesis tool as Magma, DC, Timing sign off tool as PT, simulation tool such as Modelsim or VCS.
6. 3 years + work experience.
Plus:
1. Design verification background.
2. ATE Testing background.
IC人才网原链:http://www.jobic.cn/Html/JobDetails/11899.html
10月份注册简历赢ipad:http://www.jobic.cn/Resume/Register.aspx
邮箱:jobic_cn@126.com
电话:0755-26490606 |
