查看: 1773|回复: 0
[招聘] 招聘SoC FPGA engineers --Beijing
发表于 2011-9-26 15:10:55 | 显示全部楼层 |阅读模式
SoC FPGA engineers
Job Description:
•        This position should perform Pre-silicon (FPGA) implementation of the ARM based SoC chips for mobile devices.
•        Support FPGA user design, testing and troubleshooting.
•        Engage FPGA prototyping domain technical skill improvement and engineering process improvement
Responsibilities:
•        Define FPGA prototyping methodology and strategy.
•        Draft FPGA design spec and development plan.
•        Keep tracing and improving FPGA validation technology, methodology, flow and define/improve the engineering processes.
•        Develop FPGA DV and sanity check test case.
•        Implement FPGA integration based on FPGA prototyping strategy.
•        Experience in Logic design with high-level description language like VHDL/Verilog. It will be an added advantage if the code were written to be FPGA friendly.
•        Understand the custom requirements of a Complex ARM based FPGA design which includes: ARM boot-up requirement, complex clock tree scheme, RAM/ROM inferring, and some basic analog blocks/interface like PLL. Experience with Radio RF will have an added advantage.
•        Ability to translate ASIC design into FPGA by translating clocks, RAM/ROM and  other essential analog block to equivalent  FPGA device components and requirements.
•        Familiar with Synthesis with Synplify with clear understanding the interface/timing constraints, and ability to clean all timing issues before P&R phase.
•        Familiar with FPGA tool to ensure bit file generation fits the size, performance and I/O of the design.
•        Understand FPGA board requirements and co-design with HW team
•        Responsibility to verify the net list so that it will be fully functional when downloaded on FPGA board.
Requirements:
•        Candidates must have at least 4-6 years of relevant experience.
•        Master’s/Bachelor’s Degree in Electrical/Electronic Engineering with an emphasis in IC design
•        Must be familiar with Xilinx and Altera devices and their tools
•        Must be familiar with Synplify synthesis tool
•        Must be able to understand and debug FPGA boards.
•        Must understand tcl/shell scripts to construct or modify constraints files.
•        Knowledge about complete life cycle of IC and FPGA development.
•        Knowledgeable in digital High Speed GHz frequency design and RF Radio is an added advantage
•        Knowledgeable of ARM based SoC design is an advantage
•        Good written and communication skills
•        Experience in WLAN, BlueTooth, GPS, NFC, FM or Modem (LTE, TD-SCDMA, WCDMA) SoC/IP design is preferred.
•        Experience with muli-site/multi-team/multicultural cooperation is preferred
联系人:judy
有意向者可以先把简历发至我邮箱或电话联系了解更多职位信息。
Email:digital2@kthr.com
Mobil:13764174419
GMT+8, 2025-12-20 22:16 , Processed in 0.019367 second(s), 5 queries , Gzip On, Redis On.
