查看: 4842|回复: 3
[讨论] pt中 source latency
发表于 2011-9-16 11:26:34 | 显示全部楼层 |阅读模式
pt中设置set_clock_latency -source 1 clk
默认launche path和capture都会有source latency的值
有什么命令可以让launche path有source latency,而capture path没有source latency
发表于 2011-9-16 16:03:24 | 显示全部楼层
sage: set_clock_latency    # set clock_latency
        [-rise]                (specify clock rise latency)
        [-fall]                (specify clock fall latency)
        [-min]                 (specify clock rise and fall min condition latency)
        [-max]                 (specify clock rise and fall max condition latency)
        [-source]              (specify clock rise and fall source latency)
        [-early]               (specify early clock source latency)
        [-late]                (specify late clock source latency)
        [-clock clock_list]    (specify list of reference clocks)
        delay                  (clock latency)
        object_list            (list of clocks, pins or ports)
估计 -late , -early 可以具体控制吧
发表于 2011-9-16 21:39:35 | 显示全部楼层
回复 1# kuyu200
      你设了-early -late, tool 会自动选择最悲观的组合,所以 -early 0 -late 1 就可以了
 楼主| 发表于 2011-9-18 22:11:52 | 显示全部楼层
thanks for your answer. I will try it again.
GMT+8, 2025-12-14 01:19 , Processed in 0.021701 second(s), 6 queries , Gzip On, Redis On.
