查看: 9349|回复: 2
怎样在ic5141中安装mmsim61?
发表于 2011-9-15 16:33:39 | 显示全部楼层 |阅读模式
由于我的spectre版本太低,导致spectre rf仿真出现license问题:
Command line:
/apps/Cadence/IC5141/tools.lnx86/spectre/bin/32bit/spectre -env
artist5.1.0 +escchars +log ../psf/spectre.out +inter=mpsc
+mpssession=spectre1_4942_2 -format sst2 -raw ../psf +lqtimeout
900 input.scs
spectre pid = 5271
Loading /apps/Cadence/IC5141/tools.lnx86/cmi/lib/4.0/libinfineon_sh.so ...
Loading /apps/Cadence/IC5141/tools.lnx86/cmi/lib/4.0/libnortel_sh.so ...
Loading /apps/Cadence/IC5141/tools.lnx86/cmi/lib/4.0/libphilips_sh.so ...
Loading /apps/Cadence/IC5141/tools.lnx86/cmi/lib/4.0/libsparam_sh.so ...
Loading /apps/Cadence/IC5141/tools.lnx86/cmi/lib/4.0/libstmodels_sh.so ...
spectre (ver. 5.10.41_USR4.081106 -- 11 Aug 2006).
Includes RSA BSAFE(R) Cryptographic or Security Protocol Software from RSA
Security, Inc.
Simulating `input.scs' on eda at 3:06:12 PM, Thur Sep 15, 2011.
Warning from spectre during initial setup.
NM0: `Moin' = 800 is unusually large.
Circuit inventory:
nodes 3
equations 9
bsim3v3 2
vsource 2
Entering remote command mode using MPSC service (spectre, ipi, v0.0,
spectre1_4942_2, ).
Notice from spectre.
Waiting for available license for the Virtuoso(R) Spectre(R)-RF option.
是不是需要安装mmsim61?各位有什么好的建议吗?我的系统是redhat AS4,需要卸载以前的低版本吗?
相关帖子
发表于 2011-9-15 20:51:32 | 显示全部楼层
是的。
安装IC5141和MMSIM61,然后在环境变量里面把MMSIM写在前面。
不需要卸载。网上教程大把,搜索下吧。
发表于 2011-9-19 21:41:48 | 显示全部楼层
对,search path里写在前面就先用。不确定的话 可以 which spectre查看。
GMT+8, 2025-12-16 15:44 , Processed in 0.015296 second(s), 5 queries , Gzip On, Redis On.
