查看: 10545|回复: 2
[求助] pspice仿真,报错:"There are no data values in section number 1
发表于 2011-9-14 19:59:59 | 显示全部楼层 |阅读模式
大家好,我刚开始学pspice,各位大侠谁用过帮我看一下吧。
仿真的时候一直报错: "There are no data values in section number 1. Ignoring
this section."不能显示波形,下面是仿真用的网表,包含一个memristor子电路。
*The following subckt is the SPICE model for the memristor:
.SUBCKT modelmemristor plus minus PARAMS:
+phio=0.95 Lm=0.0998 w1=0.1261 foff=3.5e-6
+ioff=115e-6 aoff=1.2 fon=40e-6 ion=8.9e-6
+aon=1.8 b=500e-6 wc=107e-3
G1 plus internal value={sgn(V(x))*(1/V(dw))^2*0.0617*(V(phiI)*exp(-V(B)*V(sr))-(V(phiI)+abs(V(x)))*exp(-V(B)*V(sr2)))}
Esr sr 0 value={sqrt(V(phiI))}
Esr2 sr2 0 value={sqrt(V(phiI)+abs(V(x)))}
Rs internal minus 215
Eg x 0 value={V(plus)-V(internal)}
Elamda Lmda 0 value={Lm/V(w)}
Ew2 w2 0 value={w1+V(w)-(0.9183/(2.85+4*V(Lmda)-2*abs(V(x))))}
EDw dw 0 value={V(w2)-w1}
EB B 0 value={10.246*V(dw)}
ER R 0 value={(V(w2)/w1)*(V(w)-w1)/(V(w)-V(w2))}
EphiI phiI 0 value={phio-abs(V(x))*((w1+V(w2))/(2*V(w)))-1.15*V(Lmda)*V(w)*log(V(R))/V(dw)}
C1 w 0 1e-9 IC=1.2
R w 0 1e8MEG
Ec c 0 value={abs(V(internal)-V(minus))/215}
Emon1 mon1 0 value={((V(w)-aoff)/wc)-(V(c)/b)}
Emon2 mon2 0 value={(aon-V(w))/wc-(V(c)/b)}
Goff 0 w value={foff*sinh(stp(V(x))*V(c)/ioff)*exp(-exp(V(mon1))-V(w)/wc)}
Gon w 0 value={fon*sinh(stp(-V(x))*V(c)/ion)*exp(-exp(V(mon2))-V(w)/wc)}
.ENDS modelmemristor
vin in 0 pwl 0 0 4s 6 6s -3
x1 in 1  modelmemristor
r1 1 0 2.4k
.tran 0 10m 10s UIC
.plot tran v(0,in)
.probe
.end
发表于 2011-11-2 21:01:10 | 显示全部楼层
楼主问题解决了没,我也是一直报这个错误
发表于 2014-2-28 15:33:53 | 显示全部楼层
话说楼主解决了吗,这里也出现这个错误啦
GMT+8, 2025-12-25 17:42 , Processed in 0.017663 second(s), 7 queries , Gzip On, Redis On.
