查看: 24797|回复: 31
[求助] 关于LDO调整管的选择
发表于 2011-9-7 07:41:25 | 显示全部楼层 |阅读模式
在CMOS工艺中,可以选择NMOS和PMOS作为LDO的调整管
那么这两种类型的device在应用时各有什么优缺点呢
 楼主| 发表于 2011-9-7 07:42:41 | 显示全部楼层
除了NMOS的压差比PMOS的大之外
谢谢各位了
发表于 2011-9-7 08:37:07 | 显示全部楼层
http://bbs.eetop.cn/viewthread.p ... Borderby%3Ddateline
看看这本书的第42页,应该有你需要的答案。
 楼主| 发表于 2011-9-7 13:27:51 | 显示全部楼层
谢谢啦,书里的确讲的很清楚
 楼主| 发表于 2011-9-7 13:54:35 | 显示全部楼层
   针对这本书里讲的内容,我好有一些疑问,能否给我讲一下?
书中43页提到:
Load transient. NMOS HDO enjoys better AC line regulation due to better
                       PSR. DC line regulation of a regulator depends on the DC open-loop gain,
                        which is often sufficient in design (≥ 60dB) regardless of the pass element type.
                        NMOS HDO is also superior in load regulation because of the source follower
                       configuration, which has a smaller RS (1/(gm,N +gmb,N)) before and after closeloop
                        feedback
. Therefore, NMOS HDO regulator would experience less voltage
                         undershot and overshot during abrupt load current changes.
为什么NMOS HDO有一个小的RS,它的负载调整率就比PMOS LDO好?
期待helianalog 答疑
发表于 2011-9-7 14:55:31 | 显示全部楼层
你把那本书的第3章仔细看下,
Fig.3.2有个示意图。
应该是希望Rs越小越好。
发表于 2011-9-7 23:29:42 | 显示全部楼层
NMOS在大功率负载时需要升压电路,PMOS比较简单
发表于 2011-9-8 09:47:54 | 显示全部楼层
相同電路架構與MOS size下
PMOS的壓差小, 能提供電流較大, PSRR較差
NMOS反之
发表于 2011-9-27 09:06:15 | 显示全部楼层
好书,能学到很多
发表于 2011-9-28 21:10:18 | 显示全部楼层
以前看过一点LDO,翻了一下,我觉得应该根据负载调整率的定义来分析
Load_Regulation=delta(Vout)/delta(Iout)=Ro_pass/(1+A*beta)(通常不管N,P,A*beta>60dB)结果正比于Ro_pass/(gm.n+gbm.n)
GMT+8, 2025-12-14 11:13 , Processed in 0.022975 second(s), 6 queries , Gzip On, Redis On.
