楼主: icfbicfb
[原创] encounter power system ( eps ) 9.1 doc
发表于 2011-12-21 21:21:52 | 显示全部楼层
下来学习学习!
发表于 2012-4-15 21:42:26 | 显示全部楼层
感谢版主提供!下来学习一下下!
发表于 2013-5-21 09:58:05 | 显示全部楼层
学习学习
发表于 2013-8-23 06:33:18 | 显示全部楼层
Of course the timing path(s) may also be displayed together with rail analysis (IR drop) results, although they
are not in this example for readability. One example of using the timing debug GUI would be to inspect a data
path and its associated clock path. If they pass through areas of widely different IR drop, setup or hold
problems that were not seen in the nominal voltage timing analysis may be seen. The GUI is not strictly
needed here; you will see the results of IR drop in the regular timing reports. But the GUI may assist the
designer in determining, for example, the cause of clock skew.
Summary
发表于 2014-4-28 09:03:52 | 显示全部楼层
多谢FENXIANG
发表于 2014-8-23 22:09:37 | 显示全部楼层
发表于 2014-9-16 10:31:07 | 显示全部楼层
谢谢分享
发表于 2014-10-13 10:16:25 | 显示全部楼层
斑竹该免费共享资料的呀
发表于 2014-10-24 20:36:38 | 显示全部楼层
谢谢分享
发表于 2014-10-26 18:46:13 | 显示全部楼层
顶顶顶
GMT+8, 2025-12-9 02:02 , Processed in 0.017938 second(s), 2 queries , Gzip On, Redis On.
