楼主: zhuzhzh
RTL级最强验证工具spyglass
发表于 2014-7-5 19:21:56 | 显示全部楼层
资料呢 看不到
发表于 2014-7-8 15:44:15 | 显示全部楼层
谢谢。。。。。
发表于 2014-7-8 15:45:17 | 显示全部楼层
软件在哪里??????
发表于 2014-8-1 20:17:12 | 显示全部楼层
cadence和synopsys
发表于 2014-9-2 10:54:58 | 显示全部楼层
没看到文件哦
发表于 2014-9-2 11:09:37 | 显示全部楼层
Software Version:SpyGlass-4.2.0
1. $ mkdir /eda/atrenta
2. untar all .tar.gz files except LINUX64 cause it's not cracked.
   NOTE: You should first unpack the SpyGlass-<rev>.tar.gz archive and then the SpyBuilder-<rev>.tar.gz archive in the same directory when you are installing both
3. modify the file : Spyglass-4.2.0/SPYGLASS_HOME/auxi/tkgui-new/spygui.pl
   line 794 : $license_check_disabled =0 to 1;
   line 1776 : $can_license_check_be_disabled =0 to 1;
4. $ cd SpyGlass-4.2.0/SPYGLASS_HOME/obj
   $ sfk replace -bin /5589e557565383ec4c8b159cdf520985d20f84440300008b3d340c5209/31c0c357565383ec4c8b159cdf520985d20f84440300008b3d340c5209/ -dir . -yes
   (you can find a compitable version of sfk on sourceforge.net)
   (check.Linux2 will be patched).
5. config the environment viarible file atrenta.conf:
   #export ATRENTA_LICENSE_FILE=<license_file_path>
   export PATH=/eda/atrenta/SpyGlass-4.2.0/SPYGLASS_HOME/binPATH”
   alias spyglass='spyglass -32bit'
   if you don't specify the parameter -32bit when on the 64 bit OS, error will occur :
   $ spyglass -verilog test.v
   ***ERROR: Missing shared library '/mnt/eda/atrenta/SpyGlass-4.2.0/SPYGLASS_HOME/lib/libsgptmalloc-Linux4.so'
6. add command "source /eda/atrenta/atrenta.conf" to your .bashrc file.
7. done! enjoy it!
Wayne@pku.edu.cn
Apr. 20, 2010
发表于 2014-9-2 12:49:17 | 显示全部楼层
来晚了
发表于 2014-9-2 14:50:00 | 显示全部楼层
我想下载呀 怎么看不到哦
发表于 2014-9-10 13:56:17 | 显示全部楼层
怎么下载呢
发表于 2014-9-17 21:22:44 | 显示全部楼层
软件呢?
GMT+8, 2025-12-30 03:00 , Processed in 0.019028 second(s), 5 queries , Gzip On, Redis On.
