查看: 3666|回复: 3
[求助] TSMC 0.35 噪声仿真
发表于 2011-8-11 10:08:27 | 显示全部楼层 |阅读模式
使用了0.35工艺文件仿噪声,结果离奇。网上有说缺少flkmod niomod参数。我查找了下,工艺scs文件里确实没这两项。比如nch噪声相关的描述仅有:
+ af=0.85 kf=1.0E-24
不确定是不是这个原因。缺少的值又该是多少。
哪位朋友能够帮助下?
 楼主| 发表于 2011-8-11 12:01:08 | 显示全部楼层
回复 1# spqgey
    自顶下
发表于 2011-8-11 15:17:29 | 显示全部楼层
加一句 flkmod=1
发表于 2011-8-16 05:07:16 | 显示全部楼层
This seems to a  BSIM3 model. You can check the model file heading and confirm here.
Also, there should be a nlev parameter. Is it missing? Usually you see nlev=3.
I am sorry I take it back. It is not clear what model this is. It is not necessarily BSIM3 model (also called BSIM3v2 model).  Also nlev may not be needed. According to
"Virtuoso® Spectre® Circuit Simulator
Components and Device Models Manual
Product Version 5.1.41
November 2004"
nlev will not be used unless the model is a BSIM3v3 model. flkmod is used only in BSIM3v3 and BSIM4.2 models. I was confusing Hspice model with Spectre model.
So I do not know what is wrong.
GMT+8, 2025-12-18 16:11 , Processed in 0.020259 second(s), 5 queries , Gzip On, Redis On.
