查看: 6558|回复: 7
[招聘] 美光半导体 Layout Engineer 模拟版图设计工程师 热招!!
发表于 2011-7-28 09:39:49 | 显示全部楼层 |阅读模式
Layout Engineer 版图设计工程师
Responsibilities:
•        Develops and prepares multi-dimensional layouts and detailed drawings of the semiconductor devices from schematics and related geometry provided by design engineering. Work may be completed through use of CAD or other computerized equipment. Checks dimensions, writes specifications, and verifies completed drawings, artwork or digitized plots. May check design layouts and detailed drawings. The Engineer will also:
o        Follows broad instructions.
o        Contributes to technical projects with some guidance.
o        Solves problems of moderate complexity.
o        Applies judgment in interpreting results and conducting quantitative analysis.
o        Integrates thorough technical knowledge within discipline.
o        Interacts with more experienced team members and managers to resolve complex problems.
o        Applies knowledge of a single OR multiple sub-function(s).
o        May lead or train others on the team.”
Job Requirements:
•        Bachelor’s Degree in Engineering (Microelectronics, Electronics)
•        At least 3 years relevant experience
•        Custom layout and successful tape-in experience is a must; flash layout experience is a plus
•        Proficiency in layout Electronic Data Automation (EDA) tools such as Virtuoso, Hercules, Calibre in doing layout edit and Lay-out Versus Vchematic (LVS), Design Route Check (DRC), Electric Static Discharge (ESD) and NAC
•        Can work highly independently. Experience in leading a small team is a plus.
•        Good teamwork and communication skills
有意者请投递简历至: morrisontang@micron.com  谢谢!!
多个vacancy热招, 3-8年经验均可!欢迎推荐,非常感谢!
更多职位请查看以下链接:
http://bbs.eetop.cn/viewthread.php?tid=302603&extra=&page=1
发表于 2011-8-23 14:55:53 | 显示全部楼层
dingyixia
发表于 2011-12-7 18:05:24 | 显示全部楼层
同楼上,顶一下,上海的工作买房怎么办
发表于 2011-12-12 16:24:11 | 显示全部楼层
How much?
发表于 2011-12-20 10:03:01 | 显示全部楼层
是镁光还是美光?英文应该是micron吧,他一般做数字为主,flash和dram,他还有专门做模拟的部门?
发表于 2013-7-22 23:21:29 | 显示全部楼层
楼主是哪位大侠啊?美光的?
发表于 2013-8-1 15:27:32 | 显示全部楼层
怎么发简历给你?
发表于 2013-10-12 06:43:00 | 显示全部楼层
看看罢了不去不去
GMT+8, 2025-12-28 21:09 , Processed in 0.511867 second(s), 5 queries , Gzip On, Redis On.
