查看: 6332|回复: 14
[资料] 2010.12_IC_Compiler_Zroute_Update_Training
发表于 2011-7-25 11:27:20 | 显示全部楼层 |阅读模式
2010.12_IC_Compiler_Zroute_Update_Training.pdf (893.54 KB , 下载次数: 209 )
发表于 2011-7-25 12:01:51 | 显示全部楼层
回复 1# iamyy123
    xiexie
发表于 2011-7-27 23:29:00 | 显示全部楼层
thanks
发表于 2011-8-22 13:44:03 | 显示全部楼层
kankanba
发表于 2011-8-26 22:10:18 | 显示全部楼层
hen hao
发表于 2011-9-16 16:04:15 | 显示全部楼层
好好好~
thanks!!
发表于 2012-1-11 06:35:40 | 显示全部楼层
new ??????????
发表于 2012-1-11 08:45:47 | 显示全部楼层
good!!!
发表于 2012-1-11 17:53:43 | 显示全部楼层
学习了,谢谢啊
发表于 2013-8-26 14:41:33 | 显示全部楼层
After completing placement and routing or a chip assembly, you can write the completed
design to OASIS format. The OASIS data can then be used for mask creation or for input to
external tools.
You can write a OASIS file from the Milkyway Environment by using either the GUI or the
write_oasis Tcl command. To use the GUI, set the command entry mode to Scheme and
enter the Scheme command write_oasis. This opens the Oasis Out Data File dialog box,
which shows the options for converting the data from the Milkyway database to the OASIS
GMT+8, 2025-11-18 08:41 , Processed in 0.253509 second(s), 4 queries , Gzip On, Redis On.
