楼主: netshell
[资料] soc encounter8.1安装文件(15MB压缩包版本,节约大家信元!)
发表于 2012-4-1 09:20:22 | 显示全部楼层
ubuntu 10.04 安装有问题,提示的内容说是有一些包不能unpack,请问LZ有什么办法没有
发表于 2012-4-1 09:28:53 | 显示全部楼层
回复 1# wkjatzju
这是我copy的安装问题。 ubuntu 10.04 LTS希望得到LZ的帮助
Initializing InstallScape using JVM at /usr/cadence/installscape_for_soc81/iscape/runtime/LNX86/bin/java. This might take some time...
com.khanpur.util.zip.ISExtractorException: Could not unpack /usr/cadence/temp/SOC08.10.000_lnx86.Base/CDROM1/kits/tsiIndep08.10-p002.t.Z
com.khanpur.util.zip.ISExtractorException:Could not unpack /usr/cadence/temp/SOC08.10.000_lnx86.Base/CDROM1/kits/spectreRdr64b07.01-s114lnx86.t.Z
com.khanpur.util.zip.ISExtractorException:Could not unpack /usr/cadence/temp/SOC08.10.000_lnx86.Base/CDROM1/kits/tsmc2yldIndep06.20-p002.t.Z
com.khanpur.util.zip.ISExtractorException:Could not unpack /usr/cadence/temp/SOC08.10.000_lnx86.Base/CDROM1/kits/cadencehelp01.11-p014lnx86.t.Z
com.khanpur.util.zip.ISExtractorException:Could not unpack /usr/cadence/temp/SOC08.10.000_lnx86.Base/CDROM1/kits/rc_cwdDoc08.10-p002.t.Z
com.khanpur.util.zip.ISExtractorException:Could not unpack /usr/cadence/temp/SOC08.10.000_lnx86.Base/CDROM1/kits/cdsCommon64b08.01-s005lnx86.t.Z
com.khanpur.util.zip.ISExtractorException:Could not unpack /usr/cadence/temp/SOC08.10.000_lnx86.Base/CDROM1/kits/anlsLibTablePlugin64b08.10-p011lnx86.t.Z
com.khanpur.util.zip.ISExtractorException:Could not unpack /usr/cadence/temp/SOC08.10.000_lnx86.Base/CDROM1/kits/snp2db64b08.10-p003lnx86.t.Z
com.khanpur.util.zip.ISExtractorException:Could not unpack /usr/cadence/temp/SOC08.10.000_lnx86.Base/CDROM1/kits/umc2yld06.20-p003lnx86.t.Z
com.khanpur.util.zip.ISExtractorException:Could not unpack /usr/cadence/temp/SOC08.10.000_lnx86.Base/CDROM1/kits/tq08.10-d001lnx86.t.Z
com.khanpur.util.zip.ISExtractorException:Could not unpack /usr/cadence/temp/SOC08.10.000_lnx86.Base/CDROM1/kits/keymapDoc02.10-p028.t.Z
com.khanpur.util.zip.ISExtractorException:Could not unpack /usr/cadence/temp/SOC08.10.000_lnx86.Base/CDROM1/kits/cdnOAWrapIndep08.10-p002.t.Z
com.khanpur.util.zip.ISExtractorException:Could not unpack /usr/cadence/temp/SOC08.10.000_lnx86.Base/CDROM1/kits/soceDBArefDoc08.10-p001.t.Z
com.khanpur.util.zip.ISExtractorException:Could not unpack /usr/cadence/temp/SOC08.10.000_lnx86.Base/CDROM1/kits/rc_dpuserDoc08.10-s001.t.Z
com.khanpur.util.zip.ISExtractorException:Could not unpack /usr/cadence/temp/SOC08.10.000_lnx86.Base/CDROM1/kits/velocityIndep08.10-p001.t.Z
com.khanpur.util.zip.ISExtractorException:Could not unpack /usr/cadence/temp/SOC08.10.000_lnx86.Base/CDROM1/kits/SuSECompat06.01-p002lnx86.t.Z
com.khanpur.util.zip.ISExtractorException:Could not unpack /usr/cadence/temp/SOC08.10.000_lnx86.Base/CDROM1/kits/rc_libguideDoc08.10-s001.t.Z
com.khanpur.util.zip.ISExtractorException:Could not unpack /usr/cadence/temp/SOC08.10.000_lnx86.Base/CDROM1/kits/cadencehelpWrp01.10-p001.t.Z
com.khanpur.util.zip.ISExtractorException:Could not unpack /usr/cadence/temp/SOC08.10.000_lnx86.Base/CDROM1/kits/rc_userDoc08.10-s003.t.Z
com.khanpur.util.zip.ISExtractorException:Could not unpack /usr/cadence/temp/SOC08.10.000_lnx86.Base/CDROM1/kits/rc_wnDoc08.10-s003.t.Z
com.khanpur.util.zip.ISExtractorException:Could not unpack /usr/cadence/temp/SOC08.10.000_lnx86.Base/CDROM1/kits/celticDMFEEtc08.10-p002.t.Z
com.khanpur.util.zip.ISExtractorException:Could not unpack /usr/cadence/temp/SOC08.10.000_lnx86.Base/CDROM1/kits/cdsQT_OS0804.23-s003lnx86.t.Z
com.khanpur.util.zip.ISExtractorException:Could not unpack /usr/cadence/temp/SOC08.10.000_lnx86.Base/CDROM1/kits/mps64b08.01-p001lnx86.t.Z
com.khanpur.util.zip.ISExtractorException:Could not unpack /usr/cadence/temp/SOC08.10.000_lnx86.Base/CDROM1/kits/ckSysConf02.00-p068lnx86.t.Z
 楼主| 发表于 2012-4-1 19:03:48 | 显示全部楼层
回复 137# 悉你
    权限问题,你自己看看
发表于 2012-4-3 07:40:59 | 显示全部楼层
回复 138# wkjatzju
不应该啊,我是在root权限下安装的,怎么会有权限问题,synopsys安装都是一个流程,成功安装ICC610
 楼主| 发表于 2012-4-3 08:48:51 | 显示全部楼层
回复 139# 悉你
    这些包肯定没问题  我就是这么装的
发表于 2012-4-3 13:12:29 | 显示全部楼层
回复 140# wkjatzju
我相信您的,但是,您能不能说一下您的安装流程,还有linux版本问题。
 楼主| 发表于 2012-4-4 15:25:39 | 显示全部楼层
回复 141# 悉你
    RHEL 4.8  反正5确实有问题
 楼主| 发表于 2012-4-5 08:33:48 | 显示全部楼层
回复 143# r0500s2005
    已经比过去那个315个包的少了  你可以去下10.1
发表于 2012-4-9 11:18:46 | 显示全部楼层
好东西啊 ,谢谢
 楼主| 发表于 2012-4-10 16:13:48 | 显示全部楼层
回复 145# heiwen_zhang
    现在有10.1了  可以去找找
GMT+8, 2025-12-25 09:20 , Processed in 0.017700 second(s), 3 queries , Gzip On, Redis On.
