查看: 7940|回复: 29
[资料] [ebook]Switched-Current Signal Processing and A D Conversion Circuits
发表于 2011-7-1 10:07:11 | 显示全部楼层 |阅读模式
Switched-Current Signal Processing and A D Conversion Circuits - Design and Implementation
by:  [size=90%]Bengt E. Jonsson
Switched-Current Signal Processing and A/D Conversion Circuits: Design and Implementation describes the design and implementation of switched-current (SI) circuits with emphasis on signal processing and data-conversion applications. The work includes theoretical analysis, high-level and circuit-level simulation results as well as measurement results from a few of the author's circuit implementations. An extensive overview of the SI field of research is also given. The book contains an extensive overview of the switched-current field of research, and can therefore be used as a quick-reference to the field. The description of each design example has been organized to describe the entire design flow from system level design and simulation, to circuit simulation, layout and measurement as accurately as possible. Thus it is possible to follow each step in the design process. Switched-Current Signal Processing and A/D Conversion Circuits: Design and Implementation is an invaluable reference for researchers and circuit designers working with one-chip mixed-signal system solutions, and low-voltage analog CMOS design. It will also be appreciated by anyone requiring a quick overview of what has been done in the SI field.
abbr_1237cf1b88cacedcbf9f71ac9c340426.rar
13.7 MB, 下载次数: 402 , 下载积分: 资产 -5 信元, 下载支出 5 信元
发表于 2011-7-1 10:21:12 | 显示全部楼层
看看怎么样
发表于 2011-7-1 10:46:31 | 显示全部楼层
书虽然老了点,扫描质量还不错。谢谢。
发表于 2011-7-1 16:18:19 | 显示全部楼层
It's a year 2000 edition; but still a good reference.
发表于 2011-7-1 17:17:27 | 显示全部楼层
try running
发表于 2011-7-1 18:19:47 | 显示全部楼层
xie xie
发表于 2011-7-1 20:15:18 | 显示全部楼层
学习学习
发表于 2011-7-1 20:16:21 | 显示全部楼层
看看!
发表于 2011-7-1 21:27:50 | 显示全部楼层
let 's take a look
发表于 2011-7-2 02:37:07 | 显示全部楼层
非常感谢
GMT+8, 2025-12-26 07:21 , Processed in 0.030764 second(s), 9 queries , Gzip On, Redis On.
