查看: 2391|回复: 2
[招聘] 著名美资上市高科技公司诚聘RFIC Layout Engineer@上海
发表于 2011-6-22 14:49:47 | 显示全部楼层 |阅读模式
Job Description
You will work closely with a world-class team of IC designers to perform physical design of highly-integrated, high-performance ICs with RF, analog, mixed-signal, and digital signal processing systems integrated on a single chip.  Responsibilities include physical design of demanding mixed-signal and RF layout blocks, chip-level floorplanning, place and route of digital blocks, top-level chip assembly, full-chip verification, chip tapeout, and mask data verification.  This position will require strong communication and problem-solving skills.  Versatility, initiative and the ability to adapt to a dynamic startup environment are essential.
Requirement:
  • BS Degree in EE (with relevant specialization) or higher, with 5+ years of industrial working experience.
  • Experience in analog and digital IC physical design with exposure to top-level assembly and chip tapeout procedures
  • Solid understanding of physical, electrical rules and DFM rules for fine-geometry CMOS processes
  • Direct experience in RF layout and knowledge of semiconductor devices and fabrication principles
  • Proficiency in block level floorplanning, understanding of device matching issues such as WPE and STI
  • Ability to estimate and minimize parasitics prior to detailed layout extraction
  • Comprehension of isolation issues and ability to create effective shielding / isolation structures
  • Experience with industry-standard layout and verification tools (Cadence: Viruoso, Assura, Encounter; Mentor: Calibre) and proficiency in a Unix workstation environment
  • Experience with PCB layout tools, lab test and measurement equipment, VBA programming or LabView programming beneficial.
发表于 2011-6-23 15:52:11 | 显示全部楼层
我倒是基本上符合要求,看能出多少薪水了!呵呵!
 楼主| 发表于 2011-6-29 10:43:21 | 显示全部楼层
回复 2# liujun790202
    关于薪资待遇问题请私下联络我好么,谢谢!
Veronica,发送简历至veronica@genhr.com
或拨打65081009转131
或15921267159
谢谢!
GMT+8, 2025-12-19 00:10 , Processed in 0.018971 second(s), 5 queries , Gzip On, Redis On.
