查看: 8561|回复: 8
[求助] assura317for5141安装问题
发表于 2011-6-12 16:28:25 | 显示全部楼层 |阅读模式
在CentOS4.8 x86_64上安装assura 317 for IC5141,配置好license,ASSURAHOME 和 PATH后,启动icfb,出现如下错误:
Load shared object file /home/EDA/Cadence/ASSURA/tools/assura/lib/libavview.so
*WARNING* dlopen: /home/EDA/Cadence/ASSURA/tools.lnx86/assura/lib/libavview.so: /home/EDA/Cadence/ASSURA/tools.lnx86/assura/lib/libavview.so: undefined symbol: ilErrSet3
*WARNING* Failed to open shared object file /home/EDA/Cadence/ASSURA/tools/assura/lib/libavview.so
*WARNING* Assura has not been installed in this hierarchy.
ASSURA菜单无法启动
查看版本( assura -v )没有问题 (Version av3.1: Production:dfII5.1.41 Release:3.1.7)
输入avview可以启动图形界面,但是出现很多warning,主要是下面这种:
*WARNING* Cannot find /home/EDA/Cadence/ASSURA317/tools.lnx86/dfII/etc/tools/layout directory to load environment variables
*WARNING* envGetVal: could not find tool[.partition] 'layout'
 楼主| 发表于 2011-6-12 16:40:04 | 显示全部楼层
自己顶一个
 楼主| 发表于 2011-6-12 16:54:38 | 显示全部楼层
再顶一个 赚积分下新版本http://bbs.eetop.cn/?fromuid=502621
发表于 2011-7-9 09:36:16 | 显示全部楼层
is 3.17 a good version?
发表于 2011-9-29 22:42:25 | 显示全部楼层
is it cdb or oa?
发表于 2012-3-1 16:50:30 | 显示全部楼层
学习,帮顶,谢谢
发表于 2013-6-2 07:32:53 | 显示全部楼层
Is it work with Ic615?
发表于 2013-7-16 09:26:46 | 显示全部楼层
317不是OA版的吗
发表于 2013-7-16 09:36:41 | 显示全部楼层
回复 1# typhoon1105
    看看你的cds.lib中有没有定义OA的库,删除其中的avTech
avview中的warning很正常,没关系
GMT+8, 2025-12-14 11:24 , Processed in 0.624984 second(s), 7 queries , Gzip On, Redis On.
