查看: 2782|回复: 0
[求助] 请教RCD钳压电路的设计公式的一个疑问?
发表于 2011-5-31 14:47:01 | 显示全部楼层 |阅读模式
Figure 3. MOSFET turn-off waveforms with clamping.
This implies that the power dissipated in the clamp at turn-off is
PCLAMP = (1/2) × VCLAMP × ICLAMP × ∆t × f
Where, f is the switching frequency.
However,
∆t = (LLP × IP)/(VCLAMP - VOUT/N).
The power dissipated in the clamp is through the resistor. Therefore
RCLAMP = [2 × VCLAMP × (VCLAMP - VOUT/N)]/( LLP × IP² × f) (a)
It is important to minimize the ripple, Vripple, superimposed on VCLAMP to keep the MOSFET drain voltage close to
the clamp voltage. The minimum value for the capacitor, CCLAMP, is therefore CCLAMP = VCLAMP/ (Vripple × RCLAMP
× f
我想问公式(a)怎么理解,我理解是漏感电压的能量会在电阻上消耗掉,但是为什么电阻上消耗的功率那样计算的...我看的raidly也是这样写得,但是我没理解到,请大侠解释下...
参考资料:maxim AN848
GMT+8, 2025-12-21 07:08 , Processed in 0.027424 second(s), 6 queries , Gzip On, Redis On.
