楼主: lsh0211
[原创] 如何让spectre使用hspice的model
发表于 2013-8-20 10:37:30 | 显示全部楼层
谢谢,定一个,我正需要
发表于 2014-5-7 16:12:45 | 显示全部楼层
回复 1# lsh0211
发表于 2014-5-7 22:50:07 | 显示全部楼层
谢谢楼主分享!感谢啊!
发表于 2014-5-26 12:25:51 | 显示全部楼层
回复 12# kuxuanxinzai
  你好,请问你这个问题是如何解决的?我也遇到这样的情况,谢谢。
发表于 2014-5-27 08:32:53 | 显示全部楼层
回复 14# chen843263864
   这个问题还没有解决。。。
发表于 2014-5-27 16:58:19 | 显示全部楼层
回复 15# kuxuanxinzai
   哦,那请问下你是如何将spice格式转化为spectre的?是直接改的吗?麻烦请看下我这个:
.SUBCKT ndd01n60 1 2 3
*      Model Generated by MODPEX     *
*Copyright(c) Symmetry Design Systems*
*         All Rights Reserved        *
*    UNPUBLISHED LICENSED SOFTWARE   *
*   Contains Proprietary Information *
*      Which is The Property of      *
*     SYMMETRY OR ITS LICENSORS      *
*Commercial Use or Resale Restricted *
*   by Symmetry License Agreement    *
* Model generated on Jan 8, 2013
* MODEL FORMAT: SPICE3
* Symmetry POWER MOS Model (Version 1.0)
* External Node Designations
* Node 1 -> Drain
* Node 2 -> Gate
* Node 3 -> Source
M1 9 7 8 8 MM L=100u W=100u
* Default values used in MM:
* The voltage-dependent capacitances are
* not included. Other default values are:
*   RS=0 RD=0 LD=0 CBD=0 CBS=0 CGBO=0
.MODEL MM NMOS LEVEL=1 IS=1e-32
+VTO=3.79705 LAMBDA=0.00698073 KP=1.65186
+CGSO=1.6023e-06 CGDO=8.14746e-09
RS 8 3 0.0001
D1 3 1 MD
.MODEL MD D IS=1.22568e-09 RS=0.0513342 N=1.5 BV=650
+IBV=0.00025 EG=1 XTI=3.90422 TT=0.0001
+CJO=3.30513e-10 VJ=0.5 M=0.723355 FC=0.5
RDS 3 1 1e+10
RD 9 1 7.9
RG 2 7 6.7
D2 4 5 MD1
* Default values used in MD1:
*   RS=0 EG=1.11 XTI=3.0 TT=0
*   BV=infinite IBV=1mA
.MODEL MD1 D IS=1e-32 N=50
+CJO=1.25109e-10 VJ=0.5 M=0.9 FC=1e-08
D3 0 5 MD2
* Default values used in MD2:
*   EG=1.11 XTI=3.0 TT=0 CJO=0
.MODEL MD2 D IS=1e-10 N=0.4 RS=2.99999e-06
RL 5 10 1
FI2 7 9 VFI2 -1
VFI2 4 0 0
EV16 10 0 9 7 1
CAP 11 10 5.42461e-10
FI1 7 9 VFI1 -1
VFI1 11 6 0
RCAP 6 10 1
D4 0 6 MD3
* Default values used in MD3:
*   RS=0 BV=infinite IBV=1mA
.MODEL MD3 D IS=1e-10 N=0.4
.ENDS ndd01n60
发表于 2014-7-16 18:02:24 | 显示全部楼层
谢谢牛人。。
发表于 2014-8-10 01:12:30 | 显示全部楼层
spectre V7是什么
发表于 2014-9-11 16:36:26 | 显示全部楼层
转不了,报语法错!
发表于 2014-9-11 22:56:57 | 显示全部楼层
顶一个,感谢楼主分享!
GMT+8, 2025-9-19 11:06 , Processed in 0.946715 second(s), 5 queries , Gzip On, Redis On.
