查看: 11287|回复: 14
[求助] 求助 Sentaurus vD-2010.03 安装
发表于 2011-5-26 23:16:16 | 显示全部楼层 |阅读模式
运行lmgrd老出现 Failed to open the TCP port number in the license. 愁死我了
 楼主| 发表于 2011-5-27 14:46:07 | 显示全部楼层
怎么没有人帮忙呢
发表于 2011-5-27 21:04:49 | 显示全部楼层
我也遇到了这个问题,求解释
发表于 2011-6-4 12:33:02 | 显示全部楼层
我也不是高手,我遇到的时候是这样解决的:首先查看进程中是否运行着lmgrd,若有就杀掉,然后再重启lmgrd;或者重启工作站(不推荐,呵呵);如果两种方法都不行,那就是license有问题,嘿嘿,你懂滴。
发表于 2011-6-14 20:23:33 | 显示全部楼层
Licensing serving error
Check the license log file for source of the problem (Licensing Support at Synopsys Support Center can assist with general license server issues):
Could not open TCP port – try a different port number, or bring up the server as root.
Hostid is not correct – recut the license file with a correct hostid.
Hostname is not correct – edit the SERVER line in the license file to correct hostname.
Missing license feature – Check with Synopsys Sales if the customer is entitled to this feature. If yes, Sales needs to recut a license. If not, Sales can query the customer whether they want to purchase this feature.
SSS error – run sssverify on the license file.  The license integrity feature (SSS) is now required, and will produce a hard error if there are problems.
发表于 2011-6-14 20:24:13 | 显示全部楼层
Licensing serving error :
 楼主| 发表于 2011-7-6 20:20:18 | 显示全部楼层
已经成功安装了
发表于 2011-7-12 23:24:44 | 显示全部楼层
怎么解决的?
发表于 2011-8-18 11:45:40 | 显示全部楼层
change the number from 27000
to 27020
it works for me ............
发表于 2011-10-25 13:14:04 | 显示全部楼层
好东西,多谢分享。
GMT+8, 2025-12-19 06:52 , Processed in 0.026743 second(s), 7 queries , Gzip On, Redis On.
