查看: 6255|回复: 6
[原创] 求一个虚拟机下ubuntu系统安装vcs的详细教程
发表于 2011-5-26 00:13:08 | 显示全部楼层 |阅读模式
谢谢各位大侠知道,有在线帮助的更好
发表于 2011-6-28 00:33:37 | 显示全部楼层
好享有收索一下
发表于 2011-11-29 17:46:22 | 显示全部楼层
百度一下
发表于 2012-3-29 23:26:45 | 显示全部楼层
Linux version 'Fedora release 16 (Verne)' is not supported on 'x86_64'
  officially, assuming linux compatibility by default. Set VCS_ARCH_OVERRIDE
  to linux or suse32 to override.
  Please refer to release notes for information on supported platforms.
Warning-[LINX_KRNL] Unsupported Linux kernel
  Linux kernel '3.3.0-4.fc16.x86_64' is not supported.
  Supported versions are 2.4* or 2.6*.
Error-[VCS_COM_UNE] Cannot find VCS compiler
  VCS compiler 'VCS_HOME' not found. Environment variable
  /usr/eda/syn/vcsamd64/vcs_2011.1/linux
  (/usr/eda/syn/vcsamd64/vcs_2011.1/linux/bin/vcs1) is selecting a directory
  in which there isn't a compiler 'linux' for a machine of this type
  'VCS_HOME'.
  Please check whether 'VCS_HOME' is incorrect; if not, see below.
  'VCS_HOME'.
  <extra strings were given: <null string> >
Perhaps vcs hasn't been installed for machine of type "linux".
Or the installation has been damaged.
To verify whether vcsE-2011.03 supports machine of type "Linux 3.3.0-4.fc16.x86_64",
please look at ReleaseNotes for more details .
We determine the machine type from uname; maybe uname is incorrect.
You can fix installation problems by reinstalling from CDROM
or downloading it from the Synopsys ftp server.
For assistance, please contact vcs technical support
at vcs_support@synopsys.com or call 1-800-VERILOG
错误,有人帮解答下么?
发表于 2012-3-29 23:27:58 | 显示全部楼层
是不是fedora16安装不了synopsys的工具呢?
发表于 2012-3-30 15:41:40 | 显示全部楼层
it is so good, thanks for your share
发表于 2018-9-17 20:08:45 | 显示全部楼层
楼主怎么解决的呢?我遇到了同样的问题。非常感谢
GMT+8, 2025-9-17 13:56 , Processed in 0.178248 second(s), 6 queries , Gzip On, Redis On.
