查看: 2011|回复: 4
【isca论文4】Technology-Driven, Highly-Scalable Dragonfly Topology
发表于 2011-5-25 13:20:59 | 显示全部楼层 |阅读模式
abstract
Evolving technology and increasing pin-bandwidth moti-
vate the use of high-radix routers to reduce the diameter, la-
tency, and cost of interconnection networks. High-radix net-
works, however, require longer cables than their low-radix
counterparts. Because cables dominate network cost, the num-
ber of cables, and particularly the number of long, global ca-
bles should be minimized to realize an efficient network. In
this paper, we introduce the dragonfly topology which uses a
group of high-radix routers as a virtual router to increase the
effective radix of the network. With this organization, each
minimally routed packet traverses at most one global channel.
By reducing global channels, a dragonfly reduces cost by 20%
compared to a flattened butterfly and by 52% compared to a
folded Clos network in configurations with ≥ 16K nodes.
We also introduce two new variants of global adaptive rout-
ing that enable load-balanced routing in the dragonfly. Each
router in a dragonfly must make an adaptive routing decision
based on the state of a global channel connected to a different
router. Because of the indirect nature of this routing decision,
conventional adaptive routing algorithms give degraded per-
formance. We introduce the use of selective virtual-channel
discrimination and the use of credit round-trip latency to both
sense and signal channel congestion. The combination of these
two methods gives throughput and latency that approaches
that of an ideal adaptive routing algorithm.
 楼主| 发表于 2011-5-25 13:22:22 | 显示全部楼层
论坛出问题了,怎么第一次发附件都连接不进去?
 楼主| 发表于 2011-5-25 13:23:06 | 显示全部楼层
 楼主| 发表于 2011-5-25 13:24:02 | 显示全部楼层
yaogeili
版主帮忙,我怎么传不了附件了。
 楼主| 发表于 2011-5-25 13:44:15 | 显示全部楼层
为什么没有人理?
GMT+8, 2025-10-1 00:46 , Processed in 0.020282 second(s), 5 queries , Gzip On, Redis On.
