查看: 2812|回复: 5
【ISCA论文3】Parallelism-Aware Batch Scheduling
发表于 2011-5-25 13:14:38 | 显示全部楼层 |阅读模式
abstract
In a chip-multiprocessor (CMP) system, the DRAM system is
shared among cores. In a shared DRAM system, requests from a
thread can not only delay requests from other threads by causing
bank/bus/row-buffer conflicts but they can also destroy other threads’
DRAM-bank-level parallelism. Requests whose latencies would oth-
erwise have been overlapped could effectively become serialized. As a
result both fairness and system throughput degrade, and some threads
can starve for long time periods.
This paper proposes a fundamentally new approach to designing
a shared DRAM controller that provides quality of service to threads,
while also improving system throughput. Our parallelism-aware batch
scheduler (PAR-BS) design is based on two key ideas. First, PAR-
BS processes DRAM requests in batches to provide fairness and to
avoid starvation of requests. Second, to optimize system through-
put, PAR-BS employs a parallelism-aware DRAM scheduling policy
that aims to process requests from a thread in parallel in the DRAM
banks, thereby reducing the memory-related stall-time experienced by
the thread. PAR-BS seamlessly incorporates support for system-level
thread priorities and can provide different service levels, including
purely opportunistic service, to threads with different priorities.
We evaluate the design trade-offs involved in PAR-BS and compare
it to four previously proposed DRAM scheduler designs on 4-, 8-, and
16-core systems. Our evaluations show that, averaged over 100 4-core
workloads, PAR-BS improves fairness by 1.11X and system throughput
by 8.3% compared to the best previous scheduling technique, Stall-
Time Fair Memory (STFM) scheduling. Based on simple request pri-
oritization rules, PAR-BS is also simpler to implement than STFM.
 楼主| 发表于 2011-5-25 13:16:37 | 显示全部楼层
Parallelism-Aware Batch Scheduling.pdf (517.18 KB , 下载次数: 16 )
 楼主| 发表于 2011-5-25 13:17:45 | 显示全部楼层
哪位大哥能赠送点信元啊,刷到吐血了,对不起工资啊
发表于 2011-5-25 14:14:47 | 显示全部楼层
我也不能下了,唉ing
发表于 2011-6-4 00:17:35 | 显示全部楼层
苦苦刷元中。。。感谢楼主啊。。
发表于 2015-11-26 09:09:35 | 显示全部楼层
Thanks for sharing .......
GMT+8, 2025-12-29 08:02 , Processed in 0.023513 second(s), 7 queries , Gzip On, Redis On.
