查看: 5584|回复: 8
[招聘] AMD 内部推荐
发表于 2011-5-16 21:06:43 | 显示全部楼层 |阅读模式
部门即将开展一个新的项目,机会很好,想跳槽的朋友可以把简历传给我,合适的话我会直接把你简历传给我们部门老大的。招聘的职位从初级到高级都有,主要是digital design, verification  and enumlation. 硕士两年以上工作经验就OK了。
联系方式: yong1.chen@amd.com
The successful candidate will have a MSEE, BSEE or equivalent degree, should have good understanding on ASIC/SOC design flow and has got design experience with two or more of the following skill sets:
           RTL(verilog) coding and style checking
           makefile, perl, TCL or csh/tcsh scripts
           clock-domain-cross checking
           dynamic logic simulation or post-layout simulation
           logic synthesis or physical Synthesis
           static timing analysis
           logic equivalency checking
           ECO(engineering change order)
           top level integration
           floor planning
           pad-ring design
           clock distribution
           design for test/debug/trace
It is a plus if the candidate has one or more of the following experience/knowledge:
           X86/ARM/8051 architecture
           PCI-E/PCI bus
           AMBA bus(AXI/AHB/APB)
           USB (3.0/2.0/1.1; HSIC; host/device/OTG)
           NAND/NOR Flash host controller, BCH, or DDR controller
           Audio System
           Clock generation and control
           Low power design
           SD/eMMC host controller
           SATA/SAS
           Legacy (SPI/SMBUS/ACPI/LPC/GPIO)
           General connectivity (I2S/I2C/UART)
           Ethernet
           JTAG
The candidate must exhibit good verbal and written communication skills in both Chinese and English. Hands-on lab experience is another plus, able to understand and/or use the use scopes, logic analyzers, has knowledge or skill of board-level lab debugging.
发表于 2011-5-17 00:23:25 | 显示全部楼层
AMD现在是不是也不景气呀?我没得其他意思哈,sorry
发表于 2011-5-17 21:34:22 | 显示全部楼层
有没有模拟IC的职位?
发表于 2011-5-19 16:36:47 | 显示全部楼层
希望是内部 不是KT
发表于 2011-5-20 21:55:28 | 显示全部楼层
看股价就知道了
 楼主| 发表于 2011-5-22 10:26:08 | 显示全部楼层
很多项目慢慢转移到上海就不景气了吗? 汗
另外我强调下这次主要是设招的,主要是digital design/verification and SOC 职位,没有模拟相关的职位。北京上海都有的,最好有相关的工作经验。谢谢
发表于 2011-6-15 21:05:37 | 显示全部楼层
AMD主要做什么呢?
发表于 2011-6-16 16:34:27 | 显示全部楼层
看好APU的推出,AMD加油,不要让intel一家独大。相互竞争对消费者才有利。
发表于 2011-6-17 22:38:13 | 显示全部楼层
顶起来,还是很看好APU的,毕竟比INTEL的便宜又实惠!
GMT+8, 2025-10-31 18:56 , Processed in 0.020357 second(s), 6 queries , Gzip On, Redis On.
